Question about Cobra CPI 1000 DC to AC Power Inverter
No power from cobra cpi 1575
I bought a cobra cpi 1575 about two weeks ago and installed in my truck. (replaced an old one that had quit working) it worked great until the last time i used it it went into error mode (loud continuis beep) and the display said olp. i unpluged everything from it as this is suposed to indicate an overload on the inverter, turned the inverter off and waited (now two days) but when i turn it back on it still says olp and beeps with no power output even with nothing pluged in? i have disconected it and powered on to drain it then reconected it and no change.
  • Anonymous Feb 14, 2009
    SAME PROB BUT MY CODE IS OPP
2 Suggested Answers
messstat
  • 365 Answers
SOURCE: power invertor weill beep a few times then shut
insufficient ground...check your connections and try again...do NOT continue to use the unit if the problem persists.
Good Luck
Posted on Jun 15, 2009
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Cobra CPI 1575 comes on 3 red letters flash. Makes a annoying beeping sound for like 10 mins then goes out. Please explain what i need to do. Its Brand New in a Brand New Rig Thanks!
plug it in
the letters are the voltage / no ?
the beeping is that its not sensing ac source saying its on battery
or its an error code
May 03, 2015 | Video Game Consoles & Games
88 ac volts at receptical
Sounds like the transformer is done. Have a big switch on the DC side, to turn it off when not in use. Being on all the time burns it out.
Nov 25, 2013 | Cobra CPI 1000 DC to AC Power Inverter
M/n cpi 1575 I've had my inverter installed in my
it indicates an overload situation
not enough information provided as to voltage supplied to the inverter and the voltage of the grinder
examples are for 110 volts ac with a current draw of 4.2 amps the wattage is 462 watts or for 240 v ac with 4.2 amps the wattage is 1008 watts assuming that it is 240 volts and the inverter has a maximum ate of 1000 watts then it is overloaded and circuit protection is cutting in
check the wattage of the inverter and the wattage of the ac units you use and if there is not a 25% difference in favour of the inverter then it is an overload situation
Jul 27, 2017 | Cobra ® Power Inverters
Every time I try to log in to messenger a window pops up which says......application failed to initialze properly {Oxc0150002] WHAT CAN i DO? WAS WORKING JUST FINE A WEEK AGO
لاتقاطعوا ولاتدابروا ولاتحاسدوا وكونوا عباد الله إخوانا
Dec 26, 2009 | Yahoo YHT-630 System
What kind of fuse does the cobra cpi 150 take?
FROM WHAT I CAN SEE IF THERE IS A FUSE IT WILL BE INTERNAL, I'M SUPRISED TO SEE THERE IS NOT A RESET OR OVER LOAD PROTECTION ON THIS UNIT CALL COBRA AND THEY CAN ANSWER THE QUESTION
Aug 10, 2009 | Cobra CPI 150 BK MicroPORT Power Inverter...
Need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
BMW installation
حضرة السيد ابراهيم ابو شرخ سوف نهديك هذه الرسالة عن تطور تكنولوجيا
Nov 03, 2008 | JVC KD-S6060 CD Player
CARTRIDGE WONT ALIGN
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Cobra CPI 1000 DC to AC Power Inverter Logo
462 people viewed this question
Top Cobra Electronics - Others Experts
Gil Shultz
cwradio73
Bill Boyd
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
