Question about Sony KP-51WS500 51" Rear Projection Television
RGB out of alignment
I have a Sony KP-51WS500. It was working fine when we left in the morning when we got home the convergence was out a whack. I downloaded the service manual and tried to adjust it. I can adjust V & H size and center, but when I go to PJE mode I can change the data but it does not change the screen. The center of the screen is still aligned, but the rest is horizontaly concaved and the colors are offset left to right. Is this repairable or do I have a new boat anker?
  • verneld Feb 02, 2009
    Replaced the two ICs and a fuse, working fine now. Only problem was HV cable would not release, had to do the work on the floor. THANK YOU for the help!
  • Sony Master
  • 5,138 Answers
Replace BOTH STK ICs and CK PICO fuses they are green or yellow.
Posted on Feb 20, 2009
Describe your kp-51ws500 repair Problem Picture is distorted
If the set is appearing out of alignment. ( 3D appearance) its usually a convergence issue. Replacing the two STK392-560 ICs and pico resistors should solve a convergence issue.
Aug 06, 2010 | Sony KP-51WS500 51" Rear Projection...
Cannot converge colors on screen
This happens when convergence out ICs become defective.
Replace convergence ICs on D board to get correct picture. This qualified TV tech job.
Thanks.
Sep 06, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony projection TV when turned on a solid red line across screen when turned of a flash of red and until the tv is warmed up red ghost letters behind the normal black ones
Hi, you will have to replace the convergence circuit board on this unit. it is failing to calibrate the rgb stream.I'm sensing signal board failure as well.
Mar 08, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51ws500 Sagging Picture and blurred colors
Bad convergence Amp ics mounted to large metal heat sinks on deflection bd.Sony parts around $40.00 each-generic approx 12.00 ea.The board must be pulled out of chassis frame to unsolder the ICs.and some alignment will be needed after replacement.NOT a do it yourself job unless experienced at soldering and desoldering.
Jan 04, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
Red shadowing...
first the conv. ic's need replacement then adj.
Oct 19, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
199 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
