Question about Danby Silhouette DWC512BL Wine Cooler
Temperature control non-functional
Old Ibernia 100 bottle unit; does not respond to temperature controller; too cold; compressor on mostly.
I found a repairman who knows how to replace failed thermostats using other than OEM equipment.
WSN
Posted on Jan 21, 2009
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
1999 ford expedition , runs good doesn't overheat , but puts out no heat ?
heater core might need replaced . check the hoses going to it under the hood after it gets to operating temperature .One should be hot and the other not so much
Nov 19, 2015 | Ford Cars & Trucks
Maytag MFI2569VEM chills to the point that everything in the refrigerator section will freeze, regardless of the temperature setting on the front panel.
these tipe of units have an electronic board that controls basicly everything thats your problem you need to replace the electronic board. some times a temperature sensor wired to the elect. board fails but most of the time the board is the problem
Feb 10, 2014 | Maytag Refrigerators
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Stuck at 77 degrees!
Hi
Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the unit should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the unit are both set to cool.
3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the unit will offer very little cooling or none at all.
hope you will be helpfull..
Thanks for contacting fixya.com
Sep 10, 2009 | Cuisinart CWC-1200 Wine Cooler
Compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
May 10, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
I have a kelvenator 2 door glass refrigerator that is not keeping tempurature it has 2 fans on the evaporator. I had a company in to look at it and they took out the old gas and charged it with the proper...
Evaporator temperature is what controls on and off operation and indirectly controls the case temperature. The charge in these system does have to be correct to the ounce. To much charge and the evaporator Pressure will run end giving a higher temperature. To little charge and it will only frost part of the evaporator. These system are critically charged systems.
These type of systems are controlled by the thermostat which should cycle off at a preset temperature and not return to the on position until the cooling coil reaches 37-38 degrees. Setting the control to cold will cause the evaporator to freeze up. Turning the temperature control to the off position will allow the fans to melt the ice from the coil. When reseting the control set it to #1 or 2 setting to begin with.
Also an old unit with an old compressor may not allow the unit to reach design temperature before freezing up the coil.
Jul 20, 2008 | Refrigerators
Danby Silhouette DWC512BL Wine Cooler Logo
241 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
