Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Maintance When I set my unit up for the summer, is there any maintance I should do first? We store it in the garage in the winter(denver,co).
  • 105 Answers
Check for dust buildup on both hot & cold coils, including any filters. Clean as required. Power washing can be used, provided water is kept away from the fan motor & controls. Allow to dry thoroughly before using. Vacuum cleaning is also acceptable. Note than on some units, the hot coil will have dirt buildup on the inside of the coil.
Posted on Jul 15, 2007
SOURCE:
How do I get my requid maintance light to go off
It usually means its time for a sensor to be replaced because its old or bad. Some vehicles has it set to come on when its time for an oil change. There are a couple of things you can do. First thing is you can unhook your battery for a few minutes, if the light stays off then your good to go. If it comes.back on then there is something wrong. The second and probably the best thing to do is go to your local Advanced Auto Parts store, they will hook it to a tester free of charge to see why the light.is on and turn it off as well if it can be turned off.
Aug 16, 2014 | 2002 Honda Accord
It hasnt been a month since the oil was changed in my 2011 Toyota Camry and the maintance required was reset. Now the maintaince required has now came back on. What would the the problem since I know
Take it back to the oil change place. Or check the oil. If a seal is leaking or oil filter was not tightened or put on correctly oil may have leaked out and you will blow your engine!
Is is there any oil leaking in garage or driveway or where you park?
Jul 25, 2014 | 2011 Toyota Camry
FIRST TIME IN WINDOW AFTER WINTER AND WHEN I TURN IT ON , I GET A HUM WITH AC BUT NO FAN. FAN MODE DOES NOT RUN AT ALL.
Since you remove the window unit in the Winter and reinstall it in the Summer, as you should. Check the inside of the unit to make sure there's nothing blocking the fan blades. If you stored it in a basement or exterior shed or garage, a Field Mouse may have built a nest in it. Believe me, I've seen stranger things than that happen.
Jun 08, 2011 | Heating & Cooling
My 1999 Chevy Silverado is has Electronic Shift 4WD and the AWD Button is Lit and won't shift ,4WD Maintance Required Light is on ,when you turn the wheels it feels like it is in 4WD but after Bareley...
When The ( maintance required) light is on it is telling you that their is an electronic fault in the four wheel drive system.You will need to have a scanner hooked up to help diagnosis the fault. their are several micro computers and solenoids in the system and it would be to expensive to guess which parts my be required to make the system function correctly
Dec 14, 2010 | 1999 Chevrolet Silverado 1500
No longer have maintance manual. Which fuse is
If it is not on the cover of the box, you can buy a tool at the parts store for around $5 or $10 called a fuse tester that reads the continuity of the fuse and tells you if it is good or bad without ever removing it. It is a wonderful tool for identifying bad fuses and eliminates the need for the fuse key. You have to go to the parts store to buy the fuse, anyway, so it is not a bad idea to get this tool.
i hope this helps
matthew
Nov 21, 2009 | 2001 Volvo S40
HOW DO I RESET MAINTANCE REMINDER LIGHT
go to garage with computer for reseting engine mange
Jul 29, 2009 | 1990 Plymouth Voyager
Maintance light came on
could be you need: an oil change, wires and plugs, etc. you need to take it to an autoshop to have them see why it is on
Sep 10, 2008 | 2000 Jaguar S-Type
Canon mp530 all-in-one
have you tried cleaning the printhead. on the printer there is a button that's labled menu, go to maintance and selelect print head clean. after the printer has done this, in the same section "maintance" you can print a nozzel page and that will show if if there's a blockage in the print head. if the nozzel check is ok, and your getting the problem when you print from the computer, check the setting and make sure you haven't got it set on draft or lower. Good luck
Feb 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Heating & Cooling Logo
115 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
