Question about Microsoft Fingerprint Reader
HELP Is it possible that i use that reader to store fingerprint as an image ( any format) cause i need to work my own verification code ,, if nto , is there any subs
  • jest246 Jun 07, 2008
    does microsoft fpr have a memory to store fingerprint image(template)..........as it can transfer only specific bits/sec depending on baud rate.....
  • 432 Answers
Are you thinking about buy one? You want to know if it will work for your needs? Ray CompuGuy44
Posted on Jun 21, 2007
SOURCE:
Fingerprint reader working but not showing image
From the description it is a software problem, If you were sticking things in the scanner bar that would not help and it will prevent the laptop from working.
Mar 30, 2012 | HP Compaq 6910p Notebook PC PC Notebook
The lock is sounding off like an alarm when we close the door to leave. What does this mean?
I downloaded the PDF file for this lock to find out about the beeps. I had to use Internet Explorer; Firefox wouldn't work. This is what I found:
Single, Short Beep - Indicates that any operations sequence has
begun OR that the door has been successfully locked or unlocked
OR that the sliding cover has been left open for more than ten
seconds.
Single, Long Beep - Indicates that programming operation was
successful
Short, Double Beep - Indicates that individual fingerprint user
deletion sequence has begun.
Long Double Beep - Indicates that Delete All programming was
successful
Four Beeps - Indicates unsuccessful enrollment/unsuccessful
verification attempt OR BioAxxis® BD1 was improperly installed
(see Installation Guide).
Six, Short Beeps - Low battery alert, change batteries
The link to download this file is here:
http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1_Complete_User_Manual.pdf
This is a PFD file, requiring that you have Adobe Reader installed on your computer to view it.
This is a link to AxxisBiometrics webpage, which has a toll-free help number blasted across it, if all else fails:
For a $250 lock, if you the beep codes I supplied you doesn't answer your question, I wouldn't hesitate to call them up. Good luck!
Jul 24, 2011 | Deadbolt Bioaxxis Bd1 Biometric...
The alarm is setting off an alarm with in the lock itself? what does that mean?
seconds.
successful
successful
For a $250 lock, if you the beep codes I supplied you doesn't answer your question, I wouldn't hesitate to call them up. Good luck! (duplicated to clear both requests for help)
Fingerprint reader says not connected on laptop
Your product appears to be
Processor: Intel Core 2 Duo processor T5750 (2.0Ghz)
Video Card: Nvidia Geforce 9300M G (128MB)
RAM: 3GB
Hard Drive Capacity: 320GB
Screen: 15.4-inch TFT WXGA (1280 x 800)
Operating System: Windows Vista Home Premium with Service Pack 1
Optical Drive: DVD Multi-Recorder
Ports: 3 x USB, D-Sub out, S-Video out, Ethernet, E-SATA, HDMI, 4-in-1 card reader, ExpressCard, Line-in, Microphone-in, Audio-out
Other Features: Webcamera, Built-in microphone, Fingerprint reader, dedicated numberic keypad, Touch-sensitive keys
Included software:
- Bullguard (Trial)
- Home Cinema (CyberLink [email protected], PowerDirector, CyberLink YouCam)
- Microsoft Office (Trial)
- Microsoft Works
- Nero 8 Essentials (BackItUp, Burning ROM, ControlCentre, CoverDesigner, Express, MediaHome, Recode, ShowTime, StartSmart, Vision, WaveEditor)
- Softex OmniPass that can store all your personal data and fill up the username and password box with a swipe.
- Ulead PhotoImpact12
Medion Akoya MD96970 | $999 | | www.aldi.com.au
For: Piano black finish; Noteworthy specifications; Touch-sensitive keys; Fingerprint reader and encrypting software; Well-spaced keyboard and numeric keypad; Abundance of ports
Against: Finish is prone to fingerprints; Screen is highly-reflective; Issues with fingerprint reader software
Conclusion: An affordable notebook for users who want a powerhouse.
Your product appears to have been purchased through a store in austrailia called aldi
My only recommendation here is
1. Contact Aldi for support about the fingerprint reader issue.
I can find no sufficent data about the problem to help you farther !
Thank you for choosing FixYa!
Az.
Sep 18, 2008 | Medion Computers & Internet
Fingerprint reader stopped working
You may need to download new drivers for it. Also position and if there is anything on it that might cause a film over ie moist fingers,grease,oil ect. will cause an issue. Fingerprint readers are notoriusly fickle.
Jul 11, 2008 | Computers & Internet
My fingerprint reader won't work. When I set it up it takes my fingerprint three times without a problem. When I'm done inputing the fingerprint and finish it asks for one more to...? At that point I get a...
if this is a reader that plugs into a usb port there are a few things that are problematic with them. They use a suspension that is very sensitive to heat if you leave your reader in the usb port the power from the port causes it to heat up and fail. The other issue is the speed of the port, Most software uses a redundancy software that verifies the image by what they call checksum points. If the speed of the port is to slow this will cause a misread. When not in use don't leave it in the port remove it and keep it cool. Good luck.. Be mucho Blessed..Mark
Jun 26, 2008 | Toshiba Computers & Internet
If a screen popsup requiring user input is it possible that the screen you are referring to is getting shot down by a popup blocker?
Sep 23, 2007 | Microsoft Fingerprint Reader
Laptop fingerprint reader
http://www.newfreedownloads.com/find/fingerprint.html
Jun 26, 2007 | Toshiba Satellite M105-S3004 Notebook
HELP
I'm not sure that this device works like that, however you could try to set it up like a standard scanner. perhaps windows scanner & camera wizard may help Gareth
Jun 22, 2007 | Sony FIU-600/W Fingerprint Reader
Microsoft Fingerprint Reader Logo
484 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
