Question about LG 37LB1DA Television
Our LG 37LB1DA is scrolling through channels
Independently, out of the blue, it has begun to start scrolling through the channels, similar to a scan, however without any prompting from us. I try to turn it via the remote and although you can see the light flicker, it won't respond. It has once or twice turned off, only to turn back on by itself!
It's installed in a built-in cabinet in our kitchen and we're unable to reach the TV controls that are underneath the TV itself (that was well thought-out!) to be able to turn it off that way, also because of that mounting we can't pull the plug.
  • whitwdm Jan 19, 2009
    thank you, since we're unable to unplug the tv (due to how it's installed in our kitchen), we'd have to shut off the breaker.Since you mentioned possible corrosion, it IS installed above our dishwasher so it's possible that the steam from the dry cycle could be the cause. None of this happened when we had the TV in another location of the house and it's only a couple of years old. We'll have to have someone check it out - thanks!
  • 11,896 Answers
I have seen problems similar to yours in the past. Several causes can make the channels change by themselves. Some corrosion on the main board near the channel up/down switches for one. The next common cause is that the EPROM may be failing or a fault with the main control processor. A good test to see if the EPROM is having a problem is to program in all the channels off the cable and then unplug the TV over night and then plug back in the see if any channels are missing.
Posted on Jan 17, 2009
  • Nate Stansfield
    Nate Stansfield Jan 19, 2009
    Steam and moisture would definately cause some internal shortage. If
    your tv or comp monitor is outside for a few hours, You are supposed to
    wait almost a day for it to warm up and dry because they short out. So
    yes. them steam would cause internal problems. And it definately sounds
    like an internal short, probably on the main board.
How do you program channels over the air
Hi, on your remote press menu, scroll to "tuner" then select "air", then below should be "auto scan" scroll to it you have an option to stop< and start> press > (or just enter to start your scan for new channels. If you get stuck, hit the menu button again and begin again. Have a great day.
Sep 28, 2014 | TruTech Televison & Video
Tv just changes colors whenit comes on
Hi Cory
Try going to menu on the remote, choose picture and follow the instructions on how to stabilize the colours.
good luck
kolbrun
May 26, 2014 | LG 37LB1DA Television
Is there a way to stop the burn-in mode on a lg tv
In the Menu, there should be options to disable or change how the TV handles burn-in, which might be called Anti Image Retention of something like that.
I have a lg 37lb1da tv that is flashing red blue green when you turn it on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
LG 37LB1DA flat panel TV
most likely the inverter board is faulty, I think this model has two of them, look on ebay for cheap replacement.
Mar 24, 2017 | LG 37LB1DA Television
I need code to activate my tv and channels
You probably need to SCAN the channels.
Connect the signal source to the tv. Either cable or Antenna.
Enter the menu mode on the tv. You can do through the remote.
Scroll down to the signal source. Select the signal source you have connected to the back of set.
Scroll to SCAN in the menu.
SCAN in the channels.
Exit menu mode.
You can now watch available channels.
Feb 09, 2011 | Televison & Video
Where can i get the channel list for my eurovox EX5100 pvr blue
Hi, Please try the below mentioned steps: AUTO SORT OFF B4 U MANUAL SCAN A CHANNEL/S: Go into Menu / Installation / Fast Install and press OK (enter pin) Now press the red button on the remote for advanced install Scroll down the options and turn Fav Sort off then press exit (do not press OK) if you press OK all channel order will get sorted back to the default order MANUAL SCAN ALL CHANNEL?S: follow AUTO SORT OFF After you press exit you get a list of frequency?s press red button (update) to update all channels MANUAL SCAN ONE CHANNEL: On the channel that?s scramble press the info button twice and make a note of the frequency at the top left, now follow AUTO SORT OFF when u press exit u get a list of frequency?s scroll down till you get to the frequency you made a note of and press ok to tick the box then press blue button for manual scan else....do a factory reset on the box m8 then rescan for chanells then leave your box on sly sports 1 to update
May 19, 2010 | Computers & Internet
I have a Proview TV that we just bought from Rent A Center and when we connect our cable to the TV it tells us to scan the channels. We did this and still we get a blank blue screen that says No Signal....
Try this as your model is basically the same as mine.
Push Menu on your remote.
Then a small screen comes up.
Using your left right arrows move left to set up.
Scroll down to tuner mode and again using left right arrows, there are 4 setting you can choose. Once the setting you choose is showing then scroll up to Channel Searching and hit OK on your remote. This will scan all the channels Digital and Analog.
Depending on which of the 4 setting you picked on TUNER MODE you may have to do this again in the next mode to see which will get the most channels on your TV.
I hope this is helpful; Ken, Attica, NY
Nov 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Changing channels with XM radio
Push the button just to the right of present number 1 and this switches the setting between scan and scroll while in XM mode.
Jul 02, 2008 | Alpine CDA-9883 CD Player
LG 37LB1DA Television Logo
299 people viewed this question
Computer Repairing
Computer Repairing
