IVE CLEANED OUT THE PUMP AT THE FRONT OF MY HOTPOINT WT741......
And it is still giving me the error code F-05,
i attempted a rinse and spin and the code has come up again half-way through, got lots of coins and stuff out of it so i thought that would be it.
The white plastic filter piece inside also looked as if it was broken ?
can anyone help, hotpoint want £150 to repair !!
  • shirley_meig Jan 18, 2009
    Hi thanks for your answer!
    we managed to get it going again before i saw your reply, the hubby had put the filter bit back in backwards DOH!
    thanks anyway
    President:
  • 373 Answers
F05 - Pressure switch jammed on full - Check pump for blockages.
There could be something still blocking the drain pump.Calling a tech for this purpose might pull in a lot of money which could be wastage as it is something that can be fixed by yourself.Provide me with the model number and will get the internal diagrams of the washer so that some disassembling might help out.Also check the filter as you say it is a little broken.Run the washer without the filter and any clothes;only with hot water for that might clear a little more.
Good luck.Please do rate my answer.And also I hope some comments with the model number.
Posted on Jan 17, 2009
I have a hotpoint wt741 washing machine and came up error f-05 I cleaned the filter out no joy. Then drained and put washing on fast spin which it did then pumped the washer full of water again help?
YOU COULD TRY CHANGING THE PRESSURE SWITCH.THIS IS A ROUND PLASTIC ITEM WITH A PLASTIC PIPE RUNNING OUT OF THE BOTTOM OF IT.EASILY ACCESSIBLE BY REMOVING THE LID
May 05, 2013 | Washing Machines
My washer hotpoint wt741 is flashing up f05 and wont rinse water out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Try this out:
Small panel at rear of machine reveals the pump,
Pull of the two pipes (Plastic clips hard to get off, Slide them sideways),
Remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left,
Pump can then easily be cleaned.
Mar 06, 2010 | Hotpoint Washing Machines
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove lower rear cover of washer.
Remove large black hose on bottom of tub.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
This should solve the problem.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Locate and remove large black hose fastened to drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
Hi.
F05 meqans that pressure switch is jammed.
You will neeed to call an engineer.
Jun 12, 2008 | Hotpoint WMA35 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Error code f 05
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Sep 17, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
