Question about Dell Dimension 4700 PC Desktop
Is this hard drive sata or ide - Dell Dimension 4700 PC Desktop
  • 1 more comment
  • rorreo Jan 18, 2009
    im sorry i tried to make a comment on someone elses thread ill delete this one asap
  • Starnley Johnwells
    Starnley Johnwells May 11, 2010
    which drive? pls specify and clarify
  • kennethdrenn
    kennethdrenn Aug 12, 2012
    SATA
  • 1,031 Answers
The Dimension 4700 replaces the Dimension 4600 (a former PC World Best Buy) in Dells lineup of value systems. With the 4700, Dell takes advantage of Intels new 915G chip set to add such new features as 5.1-channel sound and HDTV, wide-screen, and dual-display support. The chip sets built-in Graphics Media Accelerator
Storage controller Type: 1 x Serial ATA - integrated
Controller Interface Type: Serial ATA-150
Channel Qty: 4
Storage controller (2nd) Type: 1 x IDE - integrated
Controller Interface Type: ATA-100
Storage Hard Drive: 1 x 160 GB - standard - Serial ATA-150 - 7200 rpm
Optical storage Type: DVD+RW - ID
Posted on Jan 23, 2009
    Scholar:
  • 86 Answers
It is SATA - Serial ATA (DELL Dimension 4700)
Posted on Jan 17, 2009
4 Suggested Answers
  • 77 Answers
SOURCE: Can i Install PATA hdd on Dimension 4700
I'm sorry, but I couldn't wade through this bunch responses, so I'm going to give you my own.
You have 2 sata drives installed, already, so you cannot add an additional one w/o a bunch of wonky adapters, so use the IDE channel. You say you have an IDE rom drive. Well, there's a reason there are 3 connections on an IDE cable. One side goes into the motherboard, the other 2 into your drives. The motherboard side is the one furthest away from the center connector. I assume you have the primary connector connected to your rom drive. the 2ndary one would be on your hdd. Why people asked you why you're doing this is beyond me. It works, you'll have an extra drive, your preference. Whatever.
Let me know if you have any more inquiries.
To answer your questions from your original post directly, the other 'ide' channel is specifically for a floppy disk You CANNOT connect an IDE cable to it. And yes, you can connect an  hdd to the slave port on the ide cable.
Posted on May 01, 2008
MDoe
  • 156 Answers
SOURCE: Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Posted on Aug 21, 2008
SubliMation
  • 219 Answers
SOURCE: extremely slow transfer speeds from IDE hard drive to Sata
Yes, I'm afraid it's some form of difficulty in sending files from the SATA data-stream to the IDE ATA drive. It may be motherboard-specific, I don't really know. However attempting to send data between SATA and ATA drives is as I described above. Sending an 18-wheeler down a two-way highway and having the truck make a U-turn to reach the opposite drive.
Sorry I can't confirm if it's motherboard specific, I'm limited in that field of knowledge.
Posted on Feb 18, 2009
Is a ide a hard drive
You should check what kind of hard drive is using your computer. If it has less then 5 years probably hard drives are sata.
watch this tutorial
Instructions on USB To SATA IDE Adapters Cables
How to connect SATA devices in PATA IDE only PC system
Modding Guide Inline SATA Connectors
How to connect an IDE drive to SATA motherboard
Jul 22, 2015 | Hard Computers & Internet
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
I want buying the extension of lace hard drive 160 g between the adapter and the hard drive.
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
hope this helps
May 27, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Mar 21, 2011 | HP Compaq Presario V2000 Notebook
Subject: SYBA SD-SATA-IDE-B Tuesday ? 25 August 2009 When I bought a SATA Hard Drive for my second computer IDE slot, I purchased the only type of IDE-SATA dongle they had in stock. As it turns out I got...
How I solved the SATA IDE Dongle problem: I looked up various devices that perform this task and I found that some of them are bidirectional with a switch attached to them to internally facilitate the necessary configuration change. I plan on buying a PCI card with SATA ports to accommodate my switchover as it makes it easier to have my previous secondary drive connected so I can easily transfer files and provides a means of having more than two hard drives on my computer should I find the need in the future.
Aug 25, 2009 | Seagate 1 TB SATA II Hard Drive
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Sata and IDE hard drive
hi there,
yes your motherboard would allow this .. once you configure in the bois your boot drive being the IDE drives ....the operation of the other drives should be a breeze ...
Apr 27, 2008 | ASUS P4S8X Motherboard
Dell Dimension 4700 PC Desktop Logo
446 people viewed this question
Alun Cox
