Question about Logitech QuickCam Connect Webcam
Software installation unsuccessful
When I tried to install the software, it said error 1720. A script is required to complete the installation and to contact the package vendor. Hope you could provide me with assistance. Thanks.
  • DianeMary55 Feb 04, 2009
    I had this Logitech QuickCam Express in my computer before and took it out and now I'm trying to put it back and won't take it. I had dial up and now I don't. I need help how to put it back intro the computer. Thank you
  • Anonymous Feb 09, 2009
    Sqme 1720 error script missing
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 19, 2009
When I try to install my Virgin Movile Broadband into the USB port, I am running Microsoft Windows XP Pro, I get "Error 1720 There is a problem with this Windows Installer package. A script required...
To get rid of this error, I would suggest you to install the latest version of Windows Installer which you can download it from the link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en
Step2:
Start the Windows Installer service.
1. Click Start, type Services.msc and press [ENTER]
2. Double-click Windows Installer.
3. Set the Startup type of Windows Installer to Manual.
4. Click Start to start the service. Note down the error message if any.
5. Click OK.
Step3:
The Windows Installer CleanUp utility deletes all files and registry settings associated with a program's Windows Installer configuration.
Refer the article below which talks about the description of the Windows Installer CleanUp Utility:
http://support.microsoft.com/kb/290301
Let me know if the above steps help you.
Jun 18, 2011 | Computers & Internet
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
Can not install printer software. Goes through installation program and then has "The installation was unsuccessful." Used the Kodak clear utility, reinstalled software, receive the error message. Can't...
You need to remove the software completely to avaoid getting conflicts when installing back the software
Follow the basic steps
1) enable show hidden files and folder
2) delete C:\Documents and Settings\All Users\Application Data\Kodak
3) delete C:\Program Files\Kodak
4) run clear again at www.kodak.com/go/clear
5) reinstall the software at www.kodak.com/go/downloads
Dec 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Internet Explorer script error do you want to continue running scripts on this page? Library not registered
it could be possible that The author of the webpage you are accessing has simply made some sort of programming error and this is typically the most common reason.or that You are possibly running a pop-up killer of some kind which closes the pop-up too quickly which causes the script of the website to fail and thus giving you the error because it didnt complete.
possible You (still) have some sort of spyware or adware infection that tries to launch something such as a popup but causes script errors.
this is the most likely issue in your situation.
Solution:
1. Make sure your Anti-Virus software is up-to-date and then run a full system scan.
2. Try running a scan with other malware detection software. (Malwarebytes )
3. Be sure your are not running Rogue Anti-Virus software ( Security Center, Anti-Virus 2009, and Anti-Virus 2010).
4. Take a look into the Event Viewer to see the path of where the script is coming from. Some more detail may show up in the Event Viewer log)
5. Run windows updates and install any critical/important updates.
hope this helps
Oct 01, 2009 | Microsoft Windows Vista Home Premium with...
I am trying to install the software for the Quickcam Connect and it says Error 1720 and that a script is required for the installation to be complete and to contact the package vendor. Would appreciate...
Unplug you cam
control panel add remove programs
scroll till you find your cam or any other programs that came with your cam
don't forget sometimes cams come with other programs so do a good check
uninstall them all restart pc
after it's restarted install software and do not plug in cam until asked
LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 17, 2009 | Logitech QuickCam Connect Webcam
Error installing Logitech Quickcam communicate MP s 5500 software
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Aug 03, 2008 | Logitech QuickCam Communicate STX Webcam
I have loaded the software from disc supplied with my webcam 9000 but keep getting told that upgrades are required when I start my computer. If I say yes upgrade deletes software already installed gets...
completely uninstall everything associated with the initial install of the camera, might require going into the registry and looking for any instance of the camera. Before you try reinstalling, make sure you have the most recent version of explorer as new scripts require updated IExplorer.
Mar 06, 2008 | Cameras
Error 1720
it sounds that your were infected by virus, u cannot install that unless remove any variant on it.
The risk solution; is to remove your hard drive and connect to the other computer that has a potent antivirus.
after removing virus you take back your HDD then fixed back to original.
If this will not help, Your system was destruct by a virus so better backup your files and format and install fresh windows this fixed all errors.
If you don't want to scan the system maybe you should directly reformat it and reinstall windows.
Any problem arising thereto you can notify me for further instruction.
Jan 17, 2008 | Computers & Internet
RRor meesages
Plug ins' are bits of extra software that are attached to browsers and other forms of software. If you mean AOL then the software has not loaded properly and will require a re install, which is also the same problem as java script. Make sure you have th latest java installed first. http://www.java.com/en/download/index.jsp
Feb 15, 2007 | Compaq S6020WM PC Desktop
Logitech QuickCam Connect Webcam Logo
53 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
