Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
Picture is not coming ?
I have got BUSH TV Model # LCD42TV025HD . Iniatially the picture was coming but it has gone after few days of running . I had replaced the main board , check the power board .
But nothing is happening . If you can solve the problem I will be very thankfull to you .
Thanks
    Genius:
  • 2,920 Answers
Check the capaciters in each corner of the tv inside the back to see if any are popped up or not
Posted on Jan 17, 2009
    Sergeant:
  • 378 Answers
Just check out whether the another board except the main board which you have replaced is getting proper voltage on it.its quite possible that another board is haVING SHORT IN IT SO THIS PROBLEM.get it checked.
    Brigadier General:
  • 8,619 Answers
Hi!
Check for any loose connections in PSU board(the first PCB from the mains socket). Then you have to repair the PSU board, easy job to repair. Just unplug the leads and swap board over.
  • 10,594 Answers
Last thing left is back light inverter, check it mate.
    Sergeant:
  • 221 Answers
It can be the wire getting short from the main board towards the power supply board which helps to get the picture that needs to be checked and replaced to get the proper picture.
I got a bush 24inch led smart tv few days ago and it was fine now the red standby light isnt on at all or wont come on at all how do I fix it or get it to work again
Hi Alex, Red stand by light is not coming on means the power has gone dead. Check the fuse if you can. Replace it with the same rating one. If the set starts working, enjoy watching and if the fuse blows again, consult the TV Tech. Good Luck.
But why all this trouble? Your TV must be in service guarentee. Call the company guys to fix it.
Aug 03, 2015 | Bush Televison & Video
Bush BU102ZRH50 COMES ON FEW SECONDS PICTURE FREEZES
Corrupted firmware. A firmware update is necessary. Contact any service technician; or the authorized service center for Bush.
Feb 25, 2015 | Bush Televison & Video
How do i reprogram Bush LED 19134HD tv. It was disconnected for a few days and now it says tv has to be reprogrammed again.
If you moved to another transmitter, the channels will have changed. Re-detect the channels.
Feb 13, 2015 | Bush Televison & Video
HI I BOUGHT A BUSH TV LAST YEAR AND IT'S GONE BANG AND NOW WONT COME ON WHAT DO THINK IT MIGHT BE.
Power supply,
Search ebay of google for "power supply for bush Model number .................." Youll get the model number from the white lable usually on the rear of the tv. It may be an independant supply that youll be able to replace easily yourself or if not a tv repair shop may actually be ably to repair your original power supply at usually under £100.
Mar 29, 2011 | Televison & Video
I need an instruction manual (user guide) for a Bush T.V. model no.15w0084d
i have bush lcd32tv009hd and tv come out of standbay but no pictures
Sep 17, 2009 | Televison & Video
17 month old set; Picture gone. Direst TV repairman says it's the backlight bulb. Others say it's a Board.
it might be inverter board it is not backlight bulb according to my expertise bcoz once it goes off it dont come back
but u see inverter and CCFL backlight bulb failing symptoms are so same that u cant simply distinguish but i am sure u have one of these two problems inverter is more chance
Kindly rate me well
Regards
Zohail
May 23, 2009 | Vizio VX42L 42 in. LCD TV
Bush lcd 24 inch tv
REPLAXCE THE DEGAUSING P.T.C
Oct 24, 2008 | Bush 5693D 24" TV
Bush rf6683vpl
yes ,your tv need for repair, but if you know how to solder , try to solder your tv but be careful o short circuit coz it may damage your system.
Sep 06, 2008 | Bush 5693D 24" TV
SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Bush TV 32in
Hi. If you leave your tv in standby try switching it off properly at tv switch leave a few hrs then switch on. Have you got hifi speakers or anything that is magnetic near tv if yes move it away from set switch set off wait a few hrs then switch on. Or if the above has not sorted problem the set has a fault with the degause circuit. Its not to bad to repair but you will need to use soldering iron.
Aug 20, 2007 | Bush 5693D 24" TV
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
137 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
