Question about Maytag MAT12CS Top Load Washer
Need to a buy a coin mechanism to put on a washer/dryer
I rent out a property which has 10 peoplein it and need to kep costs down. I need to know who supplies somehting that can be attached to the machine so the tenants pay to use the washer/dryer . thanks
I have the parts u need call me at 484 680 1952
Posted on Jan 20, 2009
Why coin operated washer coin would not come back
coin mechanism is defective as people shove all kind stuff to it ,in order to save few Penney
Apr 30, 2014 | Kenmore Washing Machines
Washing machine wont come on but i check the plugs and the push button are okey . you know any other parts that needs to be replace ? thank you.
If this is a kenmore front loader (boxy type made by frigidaire), the button must be
depressed for several seconds. The second problem with this model is the "coin
mechanism" cam must be in the correct position to operate the machine. If someone
puts in coins two times without starting, it can get out of sequence with the timer.
If you have a key, open coin box and move the metal arm back until the cam advances
to just before the big dip. (with the unit unplugged). The next cycle will allow the
arm to drop and engage the microswitches. If you don't have a key put coins in the
slide mechanism as though you were going to start the machine and
depress button until machine starts, this will reset the cam to the correct position.
Hard to explain but if you look at the coin mechanism, it will become obvious.
If you need a new mechanism it is called the "start mechanism" for front loaders.
Hope this helps.
Apr 16, 2011 | Kenmore 3.1 cu. ft. Coin Operated Extra...
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Coin operated equipment
Go to searspartsdirect.com. Type in the model numbers you provided for each appliance you have mentioned. For the dryer, look under the "Top and Console Parts" heading for item numbers 64 and 66. For the washer, look under the "Meter Case" heading for item numbers 19 and 22. There is a toll free Customer Support number listed that you will need to call for availability of the keys you're looking for. They will request the vendor name (probably listed on the back of the coin box, or on the lock facing) in order to match the keys to your box. They should also be able to provide you with any other guidance and/or answer your questions. I hope this helps you.
If you need further assistance, please let me know.
Jan 13, 2009 | Roper RGX4634KQ Gas Dryer
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Maytag MAT12CS Top Load Washer Logo
172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
