Question about Weather King 12AJA4801AH Air Conditioner
Weather King Acclaim 2 Gas furnace efilters
Where do you replace them and what size are they?
    Scholar:
  • 144 Answers
If your furnace is easily accessed in the basement or a closet etc. then likely the filters are located either in the bloer compaertment (the small panel on the furnace) or in the ductwork attached to the furnace. There should be a removable cover. The size varies dedending on the size of your system. When you remove the old one it should be printed on it or you can measure it.
If your furnace is in the attic or a crawl space then you probably have filter grill(s) in your return air. Usually centrally located in the home.
Filters should be changed as needed depending on how you use your system but usually every 30-90 days.
Posted on Jan 17, 2009
Weather King Acclaim II gas furnace will kick on but the blower won't work. It will try and run for about 5 minutes and then the furnace shuts down.
Hello, First thing is verify if you are getting voltage to the motor at the low speed motor terminal tat he control board and neutral. if you have voltage, next step is to check the capacitor, Discharge it and use a meter to verify the microfarad rating, if it is too low replace the capacitor. If that checks out good then the motors windings are either open or shorted to ground and must be replaced. If you don't have voltage at the control board then the board must be replaced.
Mar 05, 2011 | Heating & Cooling
I have a Weather King Acclaim Gas Furnace and I cannot find where to change the filter.........can you help me?
On some of these, the filters are located outside of the actual unit in the silver metal duct that attaches to the bottom half of the furnace. It has a 1" cut into it where the filter just slides vertically into place. If you need additional help, call Weather King directly at (479) 646-4311.
Douglas
Sep 11, 2010 | Heating & Cooling
Weather King II Acclaim furnace cycles on and off and the house temperature never gets above 67. I've cleaned and sanded soot off of the temperature sensor. I've cleaned all the sensors and vacuumed out...
Wow, about the only thing you have not looked at is the thermostat. Have you had the gas pressure tested? Next time it quits, Ohm out the gas valve to see if it has a bad coil. I have in the past put on the gas valve one of thoes light probes and had to watch it to see when power went out. I found out it was a bad circuit board. Hope this helps.
Jan 12, 2010 | Weather King Heating & Cooling
Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Nov 30, 2008 | Weather King 12AJA4801AH Air Conditioner
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
Weather King 12AJA4801AH Air Conditioner Logo
564 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
