Question about Philips 43PP9202 43" Rear Projection Television
When tv turned screen is blank and chirping sound comes from back
Hi, we have a philips rear projection tv and it worked fine yeasterday. we turned if off and went to turn it back on and there was a blank screen, no sound and a chirping sound from the back. what is your expert opiion? michelle
  • 398 Answers
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Posted on Jun 28, 2007
Screen went blank but still has great sound.I can't even see the channel display number and it also has a chirping sound. The sound is great and all but no picture.Does this type of tv use a lamp or...
Here is th elink to Philips support page fro your TV.
Turn on the TV, if it is working you should see the light of the back light lamp. If you are changing channels and hear audio from different channels it is a good bet you lamp is open.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=60PP9202/17&slg=en&scy=US
Sep 17, 2009 | Philips 60PP9202 60" Rear Projection...
I replaced the lamp,was working fine,2 days later turned on the tv,and nothing just a blank screen..sounds works but no itcher??took the lamp back out an all seems fine there?
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | LG RU-44SZ51D 44" Rear Projection...
Philips projection back
hello from what you have explained it could be the line output transistor thats gone short circuit to get an engineer out to look at may cost ya they may not repair it in your home trust me i've tryed to repair one in the custormer home its not easy ring around for a quote good luck
shaun
May 11, 2009 | Philips 60PP9352 60" Rear Projection...
Flyback making a poping noise
You can get the replacement Flyback at the following link, and they provide free instant messageing tech support to take you step by step with the replacemnet proceedure. You need phillips 32942 flyback, its listed in their flyback catagory.
http://servicemanuals.vstore.ca/
Jul 27, 2008 | Philips 60PP9202 60" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
No Picture, No Sound
You can get a repair kit from www.magnavoxhelp.com for under 30.00 dollars.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
I think I have the same tv. Its a philips 50 in projection tv.
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Jun 14, 2008 | Philips 9P5034C 50" Rear Projection...
No picture just sound
Your projection tubes are messed up. It's a very expensive fix, just get a working TV off craigslist with a smashed screen and reuse your screen itself (usually 100-200$) or just toss the TV and upgrade to an LCD
Apr 29, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Philips ts3254c102 - no power
turned off and turn back on. Does the green "on" light is blinking in the any pattern?
Dec 05, 2007 | Philips 6P5430W 54" Rear Projection...
Philips 50pp9202, no picture but sound is fine.
I have the 51 inch of this model and I have found that usually it give you some indication before going completely out. Like color problems, sound, or just video disappearing. Most of the time it will be the convergence amps going bad, but you should have seen some color distortion. If not then it could be the vertical output. TDA8177 needs replacing and check caps around and diode, If not this then look for open fuse in HV line to crt's. Also power supply fuse like 1900, 2004, 1300, etc.
Mar 26, 2007 | Philips 50PP9202 50" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
363 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
