Question about Toshiba TLP 671 Multimedia Projector
Trying to figure out the problem
My issue with the projector is when i plug it in, only the intake fan in the Back comes on, no indicator lights or anything else comes on
    Genius:
  • 2,985 Answers
Take it back Denzil there is nothing for you to do here- it is an internal mother board connector or Power supply problem. Contact Technical Support at Toshiba for further advice.
Posted on Jun 21, 2007
SOURCE:
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
I have a viewsonic pjd5111 when plugged in and try to turn on both the temp and lamp light glow orange, the projector tries to come on I can hear the fans come on but the projector lamp does not come on,...
Unfortunately, the PJD5111 is indicating that the lamp has overheated. If you wait 45 minutes for the projector to cool down and these lights still come on, then the unit has an internal failure. The failure may be in the temperature sensor or that circuit. If the projector is still under warranty or on a maintenance plan, contact the dealer.
I wish that I had better news for you.
Feb 22, 2018 | ViewSonic PJ551 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Projector wont turn on
reset the lamp hour counter by (after you plug it in) holding down the enter, down, and menu buttons then press the power button. if it comes on, replace the lamp, it's old. if not, make sure the lamp door is closed completely and there's nothing blocking the fans.
Jul 08, 2009 | Sharp PG-MP66X DLP Projector
BLINKING TEMP LIGHT ON HP VP6110 PROJECTOR
All projectors are cooled by the use of a fan. The light chamber has its owned fan to extract the excessive heat generated by lamp. Check to see if this fan, close to the fan is operating.
Mar 23, 2009 | HP Digital Projector Vp6110 Multimedia...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
No powers ups
does the lamp try to fire up
check lamphouse and fan filter safety switches
Jan 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
Toshiba TLP 671 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
