Question about Dryers
Belt dhange how do we change a belt on ctd00 tumble dryer
  • sbrown865 Jan 19, 2009
    Hotpoint aquarius CTD00
    Thanks in advance
  • jude69 Mar 14, 2009
    instructions spot on .. thks it worked for me
    President:
  • 373 Answers
Please provide the exact model number or the brand name so that i can provide some internal diagrams that might help you out.
Posted on Jan 17, 2009
  • Suresh Thrithandam Venkata Lakshmi Narayana
    Here is the manual link in case you do not have one.
    click here for manual
    Could not find general instructions for disassembling the model nor any internal diagrams.Will do post once i find some.Try this in case you find it easy :-(simple instructions for changing belt in tumble dryer CTD00)
    remove top and one side casing only
    support weight of drum from underneath
    carefully slip drum out of door seal
    slide belt over drum
    replace drum into front door seal
    remove drum supports
    fit belt over motor shaft and around tension pulleys
    reassemble machine casings
    Pleas do rate my solution if accepted.Also would be glad to receive more comments in case these instructions do not help.Will get you more next time.Good luck.
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Hotpoint AQCF852BU Condenser Tumble Dryer
how do i change the belt on my hotpoint aquariue ctd00 model ctd00p
Oct 22, 2010 | Dryers
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint ctd00has stopped heating up how do i
You will find the thermostats located at the rear of dryer.
Remove cover, and you will see them adjacent to the heater element, change them both, even if only 1 is faulty.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Hotpoint Dryers
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
Hotpoint tumble dryer CTD00 timer
It is not a difficult job...the thing to keep you out of trouble is to make sure you get the right timer switch, then remove one wire at a time.
Remove one wire from the old timer and put it on the new timer, there is not that many wires for your timer.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 05, 2009 | Hotpoint Dryers
Hi, My Hotpoint CTD00 Condenser Tumble dryer makes a thudding sound with every revolution, sometimes it sounds like a pair of trainers are in there! What could be the problem?
Could be a worn drive belt, or more likely to be a worn rear drum bearing, common prob with dryers, you need to remove top cover, and look for anything obvious.
Thganks.
Nov 02, 2009 | LG DLE2514 Electric Dryer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Dryers Logo
392 people viewed this question
Top Dryers Experts
