Hello.I can't find enywhere battery cover for laptop Philips 15nb57.
  • Thomas F. Schneider May 11, 2010
    This is the PC desktop area you may want to put you question in the laptop section. the Philips website does not reconize your model number nor dooes it show any lpatop computers?
    http://www.support.philips.com/support/h...||type=C
    Sergeant:
  • 400 Answers
Have u tried batteriesplus.com they carry all types of batteries.
Posted on Oct 12, 2009
  • John  Hendricks
    John Hendricks Oct 12, 2009
    have u tried batteriesplus.com they carry all types of batteries.
How to remove dvd drive on aspire 5720
A) Remove the AC adapter (Charger) and Battery
B) Laptop closed turn it over, lay it down on a soft cloth on a table, Battery Bay Compartment AWAY from you.
C) The Thermal Cover is the largest cover on the bottom of the laptop. Goes from the right side to the middle, and very close to the Top and Bottom.
There are four Philips head screws to remove in the cover, before the cover can be removed.
1) Under the middle of the Battery Bay Compartment, and at the Top/Left corner of that rectangular vertical vent, in the Thermal Cover.
2) At the Bottom/Right corner of that vertical vent, in the Thermal Cover.
3) In-between the two horizontal vents, located at the Bottom of the Thermal Cover.
4) Straight above the screw removed in 3), is the last screw to remove. There is a round shaped vent, inside a square at the top right of the Thermal Cover. The screw to be removed is at this vent's Bottom/Left corner.
Once all the screws are removed, ease the Thermal Cover up from it's left side, (Middle of laptop), at an angle, then remove.
D) In the opening with the Thermal Cover removed, there is one Philips head screw to remove, then the ODD can be removed.
(Optical Disk Drive. The DVD drive)
This screw is located..............ack, ack,.......fzzzt.......ffffzzzt,......
Jun 02, 2012 | Acer Aspire 5720 Notebook
Hp notebook G61 primary internal battery replacement
1) Remove ALL power. Remove the AC adapter (Charger) and Battery. (Main battery)
2) Lay a soft static free cloth on a table, lay the laptop upside down on it, Battery Compartment facing AWAY from you.
3) Remove the Harddrive Bay Cover.
This is the large rectangular cover nearest you.
Two Philips head screws are loosened all the way, on the Right side of the cover. Then the right side of the cover is lifted up. (The Left side has plastic tabs. Swing the cover up, and out )
4) Three Philips head screws hold the Harddrive Caddy in. One on the right side, two on the left.
Remove the screws.
Grasp the Mylar tab on the Harddrive Caddy, and pull to the right.
This disengages the Harddrive from the interface of the motherboard.
Lift the Harddrive up, and out.
5) The RTC Battery is under the Harddrive Caddy.
Real Time Clock Battery.
Plugs in with a white connector, on the end of it's Black, and Red wires.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 12, 2012 | Computers & Internet
My Philips 9FF2CME/37 photo frame no longer holds a battery charge. How do I access the battery so that I can replace it? What type (make/model#) battery?
the Philips 9FF2 photo frame has an internal rechargeable battery inside the photo frame. So in other words, the Philips 9FF2 photo frame needs to be disassembled for you to be able to access the battery, then make necessary replacement.
With the Philips 9FF2 photo frame turned off and remove from the charger, get a screw driver, use it to disassemble the unit to take the back cover apart in order to gain access to the internal part to get to the battery.
Remove the battery, take it to any electronics part store in your area and get a battery replacement. It is not necessary that you get a Philips battery, all you need is a battery with the same size and volt/watt.
I hope the above is clear.
Regards.
Jul 18, 2011 | Philips 9ff2 Digital Photo Frame
My Philips 9FF2 photo frame no longer holds a battery charge. How do I replace the rechargeable battery?
Good luck.
Where can i update drivers for philiips 15nb57 EAA 89
the only site I could find for drivers
http://www.user-guides.co.uk/download/philips/philipsx58/philips-x58-eaa-89-driver.html
sorry it's not a free site, I cant find the manufactures site
Feb 24, 2011 | Computers & Internet
How to install a c-mos battery in a dell latitude c-840 Laptop
this means you will be opening the laptop cover from under, then remove the old c-mos battery, then replace with another.
The laptop must be off, battery removed, unscrew the under laptop cover, to access the c-mos battery, and that's all.
Good luck.
Apr 23, 2010 | Dell Latitude C840 Notebook
Can i replace the battery for my philips SA9122 player? it doesnt hold power anymore
its possible for you to change the battery. If the battery is an in-built, you will have the loose/open the player's cover to be able to access the battery.
Also take the battery along as a sample to get another one.
Take care.
Feb 03, 2010 | Philips GoGear HDD075/17 MP3 Player
I own a philips laptop 15NB57 series, model No. EAA-89. It came with vista but I changed it to windows xp. Unfortunately i cannot hear the sound of my audio CD or DVD. How can you help me?
go to control panel click uninstall progams look for realtek hd audio manager if not there download it from rapidshare it will work 100 percent tried it a t my cousins house.
Jan 25, 2010 | Computers & Internet
HOW TO REMOVE Momentus 4200.2 100 GB ATA hard drive FROM MY HP DV8140US NOTEBOOK SO I CAN REPLACE IT.
Here is a direct link to the maintenance & service guide for this laptop model:
http://h10032.www1.hp.com/ctg/Manual/c00554540.pdf
Go to page 93 of this PDF file, & go through the procedure described to remove & replace your hard drive.
Nov 03, 2009 | HP Pavilion dv8140us (EP407UA) PC Notebook
Neet battery cover for Philips TSU600 Pronto remote control
Battery Covers sell worldwide at Rogers for around $3-$10. Also, cheaper 50c ones are sold on EBay, Kijiji, and Craigslist.
May 03, 2009 | Philips TSU6000 LCD Touchscreen Remote...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
