Microsoft Xbox 360 Wireless Controller Logo
Posted on Dec 28, 2012
My xbox game the controller viberates it pauses the game i am playing how can i stop it from doing that
If i get hit in a game the controllers shakes and pause the game why do this happen
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
120
Points
14
Maybe you should try to wipe off the cd this has happened to various times and that allways helped me hope it helps!!!
4 Related Answers
A
Anonymous
  • Posted on Jul 03, 2007
SOURCE: XBOX PROBLEM
I have had the same problem in the past. The problem with mine was the controller wires were loose from being wrapped tightly around the controller while not in use. Try pugging in a new controller or one you know does not have issues. Good luck.
Anonymous
  • 72 Answers
  • Posted on Jan 09, 2009
SOURCE: Red Ring
Hey there,
Easiest way to fix this problem is to contact microsoft and have the console repaired. It is usually caused by the Graphics processing unit, Central processing unit, and the fan producing to much heat and warping the mother board causing the solder to become loose breaking it and loosing a good connection. Sorry for the bad news! Thing to try and practice with this console would be checking the power supply make sure it is in a well ventilated area and vents are clean, also the console must be kept clean in a open area where it can get good ventilation on all sides. since the 360 has a 3 year warranty just get the system replaced/repair and it will save you alot of grief. I hope this helps! good luck and happy gaming.
Anonymous
  • 15 Answers
  • Posted on May 14, 2009
SOURCE: Controller keeps disconnecting (not Live) pausing the game
if its wireless try changing the batteries, if its wired get a new controller because the wiring is loose.
Anonymous
  • 10 Answers
  • Posted on Aug 02, 2010
SOURCE: on screen notice says to reconnect the controller game paused
it might be the battery pack try to hold the battery pack tighter on the controller then try turning it on
How to set up for Two players at once
  1. Make sure the game you want to play allows for "Local Co-Op". If it just says "Co-Op" it might mean online, which means you won't be able to play with a friend who's actually sharing your screen.
  2. You'll need to add a second controller to the device. Do this by:
    1. Turning the controller on by holding down the XBox button
    2. Hitting the "Connect" button on the leftmost part of the skinny silver bar that runs across the front of your XBox One
    3. Hitting the connect button on the controller, which is on the top left part of the piece that's right above the XBox button.
26018364-5opx2pgqbcjwy4vp1lgyhlsx-5-2.png When you start your game, you may be asked to connect to another player profile. If you are, either use your friend's gamer ID or just use the "Guest" option that will let you save your progress.
Connect wireless Xbox One controller to your console
When I'm using either of my XBox 360 wireless controllers, any button I push pauses the game. It will play for a little while without pausing, but mostly pauses continuously. What could be the i
does it do it on just one game, or does it pause other games when you try to play, if its just that one game i would go to my memory at the dash board and delete the game from my harddrive but you would have to play it all over again(but if its multiplayer like for example it saves your rank online so you dont lose your place only your story line will be deleted not your rank in multiplayer) hope this helps if not buy the same game new again, thank you, jamie
I lost may xbox playback kit remote control what can i use as an alternative
Hey,
You can use your Xbox controller as a remote control to watch media.
Here are the actions for each button:
To... Press... Play or pause Note If the DVD is bookmarked, it will start playing automatically where it was stopped the last time you viewed it. START Skip back one chapter LB
or
A, then select skip back Skip forward one chapter RB
or
A, then select skip forward Fast forward RT Rewind LT Page up through a list of items. RT Page down through a list of items. LT Open the on-screen display for more advanced playback controls. X, Y
Source: http://support.xbox.com/en-us/pages/xbox-360/how-to/watch-dvds-movies.aspx
2helpful
While playing call of duty on xbox 360 my controller when i look up and down is working in reverse
Your control settings have likely somehow become inverted. While in-game, go to the pause menu and select options. Make sure that Look Inversion is DISABLED.
I'm playing Darksiders PC with wired XBOX 360 controller. I'm having problem where the screen kept zooming in and out automatically while playing. If I hold LT, this will stop. But once released, it...
If you are on windows 7 go to control panel and search for "game" one of the top results should be "Set up USB game controllers". Go there, select the 360 controller from the list, and hit properties. In the settings tab there should be the option to calibrate it, do so. That should stop the controller acting like you are pressing things when you aren't.
2helpful
Xbox 360 controllers wont sync when using the rechargable battery packs instead of the 2 AA cell batteries provided with the controllers. Have tried hitting the sync buttons on both the console and...
Opt out the easy way and put a rechargeable battery pack in the controller and use a plug and play controller cord to connect the console to the controller and , voila!, they should be now sync'd to each other.
I hope this helps. Good luck.
On screen notice says to reconnect the controller game paused
2helpful
Multiplayer mode Kung Fu Panda pc game
The xbox 360 wirless controller has very little lag that you would not be able to notice i would suggest just getting the controller and if u want u can also get a xbox 360 controller that is wired.
Xbox console longs in but control just flashes
There is a small button in the front of the Xbox and all you ahve to do is hit the button and hold the controller infront of the xbox it will then sink all controllers turned on and you should only have to do that once. It worked for me i hope it works for you.'
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
