Question about Whirlpool Dryers
Dryer drum will not turn
I have a Whirlpool dryer that is 4 years old. The drum will not turn. Is this something that is common that I can fix or do I need to call a service technician?
    President:
  • 373 Answers
The problem could be a faulty motor or a displaced drum belt or an internal wiring problem.Calling the tech would be preferred.But in case you want to locate the problem by yourself, post the model number here and I can help you out with few internal diagrams.Good luck,Please do rate my answer and post comments.
Posted on Jan 17, 2009
My dryer made a loud bang and wont spin
Bridgette, Most common problem is a broken belt when dryer drum dose not turn. Look through the attached links to help diagnose and repair your dryer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Drum Not Turning
Whirlpool Dryer Drum Not Turning
Appliance Repair Forums
Duet Dryer Drum Belt part 661570 How To Replace
Jul 17, 2016 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
Not spinning however has heat
It usually happen when the motor goes bad. If the appliance is more than 4 years old, you may need to request service to replace the main dryer motor. If the dryer is not that old, perhaps something is jamming the mechanism. The dryer needs to be opened to check if there is nothing (perhaps clothes) jamming the drum.
If you are trying to do it by yourself, UNPLUG all before removing any cover.
Dec 18, 2009 | Whirlpool Dryers
I have a whirlpool gas dryer, 4 years old. i
It sounds like the heating filament below the drum has either fried one of the fuses down there, or has some lint or something fallen on to it.
Did you notice if the drum still heated up? If it did, then its a bit trickier to completely ID what went wrong. If it no longer heats up now, then the thermal cut-off fuse has been blown and will need to be replaced (most common problem with a dryer)
Typically, once it is unplugged, you can open up the panel below the door (there are normally a couple of latches along the top gap that you need to push in with a couple of screwdrivers to open). Once open, you should see a heating coil that provides the hot air to the drum, look to see if there is anything in contact with the coil. If there is something there, remove it. If not, then continue below.
Now, if your dryer has stopped heating up, you need to pull the coil and replace the thermal cut-off fuse (or get someone in to do it for you). If it was still heating up, you can start the dryer with the panel open (make sure everyone and everything is well clear of the opening) and see where it is smoking from.
Nov 01, 2009 | Whirlpool GGW9868K Gas Dryer
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Eleven year old Whirlpool electric dryer cannot turn the drum with a full load of towels. The motor turns on but then shuts off. It will turn a very light load.
Turn the drum by hand. It should rotate fairly easy in one direction. If so, then the motor is going out and need replacement. Fairly common problem.
Jul 13, 2009 | Estate TGDS840JQ Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
