It's a dual sim and my friend might of set the restriction code
You can get restriction code for your Nokia 2630 from Unlocking4u.com ,and unlock it easily using unlocking instructions which is given in the site itself.
SOURCE: unlock a nokia 2630
-- ** WARNING START ** --
This is not supported by your phone manufacturer. Use this at your own risk.
-- ** WARNING END ** --
Here is a tool you can use, it works for most providers, including the two you have mentioned here: O2 and T-Mobile.
http://www.unlockme.co.uk/dct4free.html
SOURCE: nokia 2630 t-mobile
ime 352067026152911, Irlanda Meteor networ.
Pleas unlock cod for Nokia 2630, ime 352067026152911, Irlanda Meteor network
SOURCE: Restriction code for nokia 2630
hi im josh a mobile phone technician in cebu phils.may i help you? Friend your mobile phone is restricted in other sim rather than smart because the phone is set or locked to only one network wich is the SMART.in our term your phone is not openline. Friend to make your phone open line you need to go to SMART provider and ask to openline your phone.or you need to go to moble phone service center around you and they will do the job.i cant help you online coz it needs software and cable wires to do the unlocking.that would take a short time to unlock just about ten minutes so if you go you just wait your phone and donot leave it. thats all friend hope i helped you.good luck
SOURCE: I need a restriction code for my Nokia 2630. IMEI
Hii
i didnt get ur question properly ?
U need sim card restriction code ? if thats the case call up to ur network provider they will provide u with the code.
If u need ur cell phone code then, refer ur manual , by default all nokia phone codes are set to 12345
Regards. Hope it helps u
1 - Switch on your Nokia 2630 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2630.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2630 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2630 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2630
