Question about Whirlpool GR399LXHS Electric Kitchen Range
Bottom element needs replacing
Whirlpool gold GJP84902 range, I need to replace the bottom (hidden) element, what do I take apart to do this?
  • Anonymous Apr 06, 2009
    I have a Whirlpool Gold GJP84900 ceramic top stove. I need to change the bottom (hidden)element, its got no continuity.
    How do I get to the bottom element??
    Problem Solver:
The side right side panel comes off three screws hod it on the back pullout
Posted on Feb 08, 2009
The bottom element on my Whirlpool Gold Self-cleaning Accubake system (purchased in 1999) is not working. What is wrong?
Hi, Are you equipped to check the bake element to determine if it's the problem ? You may be able to see if it has a burnt section on the element via a visual inspection. If so it is the problem, if not you'll need a multimeter or a pro technician to come and inspect it. With a meter you want to check the element for continuity (unplug the range and remove one of the wires at the element first) I will add the price of a bake element is cheaper than phoning for service "IF" you can change it yourself. Hope that help's you at least reach a place to make an informed descision on whether to attempt a repair on your own or call a pro. Thank's for visiting fixya. Please take a second to rate the info I provided for you today. Good luck in whichever way you choose. Macmarkus :)
Dec 11, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Need to replace hidden bottom element on whirlpool gold GJP84900 how do i get to it
OPEN OVEN DOOR, LOOK FOR SCREW HOLDING ELEMENT TO BACK PANEL, TURN OFF POWER, REMOVE SCREWS, SLIP OFF WIRE EACH SIDE.
BOTTOM BAKE ELEMENT, TOP BROIL ELEMENT.
Oct 25, 2009 | Kitchen Ranges
Parts left over after replacing element!
here is a link to pictures of the assemblies. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=GJP84902&pop=flush Eric
Sep 14, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Sep 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
BOTTOM COIL DOES NOT HEAT UP
my bottom element in my Whirpool range needs to be replaced. It is hidden. How do you replace it?
Jul 20, 2008 | Whirlpool RF364 Electric Kitchen Range
Whirlpool GR399LXHS Electric Kitchen Range Logo
841 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
