Question about Denpa USB-24 Digital Voice Recorder
Harbinger Decoder I dont understand the manual regarding the decoding program, in the Harbinger Convert 1.4 panel it has two lines to fill in ,the top one is a source file ,the second an output file ,what do I put in these squares to make the decoder program start .
I don't Harbinger convert 1.4 manual, top one say source file and the output file what is the source file and where do I find and is the out put file any title I chose.
Posted on Oct 27, 2008
    Problem Solver:
  • 6 Answers
Okay, I'll try and help you out...
1. Create new folder on desktop called 'recordings' or something similar i.e. easy to remember!
2. Connect unit to PC via USB cable and turn on the unit. If you slide the HOLD switch to the on position, you should get a message saying "PC LINK" on the display.
3. Locate the recording(s) that you want to decode. I don't know what model of denpa you have, so I can't be sure, but there are normally four folders (A, B, C, and D - there may also be an MP3 folder). The recordings are accessed by double-clicking my computer, then the removable disk icon that appeared when you plugged in and turned on, and then opening the folders that are present which contain the recording(s) you wish to decode.
4. Identify the recording(s) you wish to decode and copy them to your newly created desktop folder (right click the file/copy and then go into new folder and paste there).
5. Once you have copied the file(s) you want to decode, open the Converter program (programs - harbinger converter - converter 1.4).
6. In the program window click on the magnifying glass in the top box (source file) and browse to your new folder.
7. Select the file you wish to decode (I think you have to do them one at a time - just repeat the process for each one following these steps).
8. In the lower box (output file) enter the name you wish to use to identify the file so you can find it. Then click on the magnifying glass for the output file and browse to your newly created folder (this will then be where your converted files will be sent on decoding).
9. Click the 'decode' button in the lower left corner of the program window (I think it shows a picture of two different sized cogs side by side).
10. The file should then be decoded from its .hgl format to a (new) .wav format with whatever name you gave it. From here, you should be able to listen to the file on your PC using any common media player (i.e. Winamp/Media Player etc.) or recode it as an .mp3 if you want to save some hard disk space on your computer.
Repeat the process from step 6 for each file you want to decode.
Hope that helps and good luck.
Posted on Dec 12, 2007
SOURCE:
How do I setup 2 tv,s on a single view dsd 1131 decoder, 1 tv and decoder upstairs an 1 tv downstairs. The dish is already installed and can rust very easily for the area.
very simple ,, the tv next to the decoder must be conected using a rca cable and then run normal tv cable (RF out ) to the other room
Apr 04, 2013 | Televison & Video
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
Does go on when we press the on button. When we unplug the TV is will go on, but we get colorful lines....unplug it again and it goes on sometimes.....we understand it could be the board. It doesnt seem...
Yes,this problem is causes by a T-CON decoder board,this T-CON decoder board sit in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Dec 08, 2010 | Maxent MX-32X3 32 in. HD-Ready LCD...
My tv turns on but it shows colored verticals lines all over the screen then turns off
If this problems,the tv is causing this by itself,not by somebody or something hitting the LCD screen panel by causing the damaging the LCD screen panel itself.If this problems is causing by the tv itself,the T-CON decoder board is dead.This T-CON decoder board sit wright at the middle bottom of the tv LCD screen panel.Replace this T-CON decoder will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Nov 12, 2010 | Sylvania LC260SS8 26 in. LCD Television
Error message says I have no decoder. What now???
You'll need a decoder from a program like cyber dvd or win dvd. Nero also has one and sonic too. If the drive came with a dvd player program install it. You can also find them through windows media player at microsoft's website but they will cost a few bucks. Search the internet for dvd player software you may find one for free. I hope this helps you. If you are like me you might have a program in your pile of software cds'.
Aug 26, 2009 | Sony Computers & Internet
I can,t able to play dvd's on window media player 11 becoz i think i dont have dvd decoder for that but i have installed dvd decoder from net it was ''dvd decoder pack for windows xp'' but when i installed...
well you can download the vlc program which can easily play the all format videos........this program u can download it from here
http://www.videolan.org/vlc/download-windows.html
Mar 13, 2009 | Microsoft Windows Media Player
I want a diagram of 4X16 multiplexer circuit ..................
it's not a multiplexer, that's called an encoder.
Multiplexers are sort-of like switches. They "choose" one of the X inputs based on an input "selector" and output it
http://en.wikipedia.org/wiki/Multiplexer
but what you're looking for is something that decodes a 4 bit binary input into a 16 bit output where for each possible input, one unique outputs out of the 16 are high. That's a four-to-sixteen line decoder.
They're kind of useless. Three-to-eight decoders are much more common.
Here's an article on how decoders work, and it shows an example of a three-to-eight line decoder. You can easily take that and extend it to be a four-to-sixteen line decoder once you understand the process.
http://cpuville.4t.com/decoder.htm
Dec 04, 2008 | Computers & Internet
DVD Rom drivers
How to detect the availability of a DVD decoder upgrade loadTOCNode(2, 'moreinformation'); If you previously clicked Upgrade Later when the upgrade page appeared in the Help and Support DVD Troubleshooter, a desktop shortcut was created. To upgrade your DVD decoder program, double-click the desktop shortcut. If no desktop shortcut exists, follow these steps to determine whether there is an upgrade available for your DVD decoder:
  1. Click Start, click Run, type dvdupgrd /detect, and then press ENTER.
After you run the dvdupgrd /detect command, any detected DVD decoders are listed with either a "yes" or "no" to indicate that there is or is not an upgrade available from the manufacturer for both Microsoft Windows 98/95 and Microsoft Windows 2000 versions of the software. uparrow.gifBack to the top How to upgrade your DVD decoder loadTOCNode(2, 'moreinformation'); If an upgrade is available for your DVD decoder program:
  1. Click Start, click Run, type dvdupgrd /upgrade, and then press ENTER.
After you run the dvdupgrd /upgrade command, you will be directed to the manufacturer's Web site where the upgrade is located. Follow the instructions on the Web site to obtain and install the upgrade for your DVD decoder program. uparrow.gifBack to the top No upgrade is available or no DVD decoder is present loadTOCNode(2, 'moreinformation'); If an upgrade does not exist or if there is no DVD decoder present, obtain and install a decoder that is compatible with Windows XP. For more information about decoder providers, please view any of the following third-party Web sites: ATI Technologies loadTOCNode(3, 'moreinformation'); http://ati.amd.com (http://ati.amd.com) CyberLink (PowerDVD) loadTOCNode(3, 'moreinformation'); http://www.cyberlink.com (http://www.cyberlink.com) InterVideo (WinDVD) loadTOCNode(3, 'moreinformation'); http://apps.corel.com/lp/ivi/index.html (http://apps.corel.com/lp/ivi/index.html) MediaMatics (DVMatics) loadTOCNode(3, 'moreinformation'); http://www.national.com (http://www.national.com) MGI Software (SoftDVD) loadTOCNode(3, 'moreinformation'); http://www.roxio.com/en/products/index.jhtml (http://www.roxio.com/en/products/index.jhtml) Ravisent (CineMaster) loadTOCNode(3, 'moreinformation'); http://www.sonic.com (http://www.sonic.com/) For more information about DVD playback support in Windows Media Player for Windows XP, and also links to third-party DVD Decoder Packs, please visit the following Web site: http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx
Aug 08, 2008 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
Mar 03, 2008 | Logitech Z-5300 Computer Speakers
Denpa USB-24 Digital Voice Recorder Logo
839 people viewed this question
Top Denpa Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denpa Audio Player and Recorder Expert? Answer questions, earn points and help others
