Question about Baumatic B180 Electric Single Oven
Baumatic B501SS Built In Stainless steel electric single oven
Both the lights on my oven are working but the oven isn't heating up
  • Baumatic Master
  • 3,463 Answers
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Posted on Jan 17, 2009
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
My grill works but the oven doesn't heat up
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Mar 31, 2011 | Baumatic B187 Stainless Steel Electric...
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
There is no heat to the oven but the fan and light still come on
You need to replace the oven element, as it will have failed, giving you the symptoms you describe.
It is located at the rear of the oven compartment, behind a removeable cover.
This should solve the problem.
Please rate my solution.
Thankyou.
Dec 29, 2009 | Baumatic B187 Stainless Steel Electric...
How do i find out what model my baumatic built in oven is?
There should be a small plate or label on the oven, giving all the details you require.
It could be at the bottom, or inside the door opening, on the rear, on the top of the oven itself, it will be there somewhere, unless it has come off.
Hope this helps.
Dec 17, 2009 | Baumatic B205SS Stainless Steel Electric...
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
Baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Aug 28, 2007 | Baumatic B187 Stainless Steel Electric...
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Oven fault code
I think your thermostat is broken, try replacing it with a new one.
Oct 15, 2006 | Baumatic B205SS Stainless Steel Electric...
Baumatic B180 Electric Single Oven Logo
461 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
