Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Error message LE5E and would only oparate prewash
My Hotpoint aqarius WF630 was working fine yesterday, today I tried to wash a load and I kept getting an error message LE5E , I turned it on and off, didnt work, I even pressed for few seconds the start/cancel as I was told couple of months ago and this method didnt work either, its stuck on prewash even if I change the dial.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
It's not on 'test' is it,
try turning the machine on while pressing the start and on buttons together until dOFF apears.
Posted on Jan 29, 2009
Hi, my Hotpoint Aquarius + WF630 screen has what looks like something E5 something on the screen and goes from prewash through to spin within a few moments and no water enters. i have made sure the drain...
If you have cleaned the drain filter AND checked the operation of the drain motor, for Hotpoint (and the manufacturer Indesit) E5 states ' pressure switch jammed on full or pump blocked- check switch and module'. Sometimes there can be bad connections between plugs/cables/module (PCB). If you haven't done already please make sure that the pump does actually work by removing the filter, seeing the pump motor and putting the machine on spin. You should see it rotate! Otherwise it looks like a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
Today I did a load of washing and it worked fine. I then started a second one and when I looked at the machine, the timer showed the number 1 and the light was on prewash. the washing had not been...
hi I think the door lock is faulty it always shows 1 min until the door lock is unlocked. also will not start until it is locked. e40 is the error for starting the machine with door open but if if faulty will revert to the last minute. include product no and model if further info needed you can find this on a label in the door area.
Nov 08, 2010 | AEG Washing Machines
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aqarius mod no wm63x all machine functions fine drum wont spin
check pump/filter/outlet hose is not blocked. if ok check the brushes in the motor.
Oct 21, 2009 | Hotpoint Aquarius WF220 Front Load Washer
My washe keeps reading either F04 or F05
F04 - Pressure switch jammed on empty while F05 is a blocked filter.
Check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an engineer.
This really is your only option.
Plz rate my solution
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Jun 06, 2006 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
129 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
