Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag LDE412 dryer.
I justreplaced the motor on above and can't figure how to put the belt on the motor pully and around the belt tightener. Does anyone have a drawing?
    President:
  • 373 Answers
Here is a link to the internal diagrams of your model.you can choose among the parts just in case.Good luck.Please do post comments and rate my answer.Thank you for contacting fixya.
LDE412 internal diagrams
Posted on Jan 17, 2009
How to put belt back on drum on my dryer
You have to take the back off of the dryer and see the motor pully and the idler pully. slip the belt around the drum, around the mototr pully and usind a flat blade putty knife, work the belt over the idler pully so that it puts tension on the belt. you may have to loosen the idler pully housing bolts, but try it first with working it over the idler as that was set for optimum tension.
Feb 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
ANt diagram of how the belt goes on the Maytag
pull the loop on the bottom of the tumbler once you have it warped around and hanging free
pull that loop twords the motor under the idler pully
both side of the loop
pull the loop twords the motor hub, you may need to left the idler pully to gain a liitle slack
once on the motor let go of the idler and it should tighten the belt
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do I replace a broken belt around the tumbler on my Maytag LDG612? Thank you.
remove front cover and access top cover screws and remove top. lift up drum and string belt around drum,set drum down and string around remaining belt around motor and idler pullys and hand manually rotate to align belts before putting top and front covers back on
Sep 24, 2009 | Dryers
My Maytag MDE308DAYW needs a new belt. Belt was
If you go from the top. The belt goes down the drum, between the drum and idler pulloy,under the idler then pull it over to the top of the motor pully and loop over it. When it comes out from under the motor pully it goes under the drum and over to the other side of the drum, and back up to the top of the drum. I hope this makes since.
Please rate solution if helpful
Aug 28, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag gas dryer. Belt broken. How do I open and replace it?
On the right front and left front of the panel there are 2 phillips head screws. They are about 4 inches up from the floor. Remove these 2 screws,lift the door panel out then down to dislodge the top clips. Remove the door switch wires and set the door aside. Remove 4 screws from the front drum support. @ on the right,2 on the left. Remove the drum support.Install the belt around the drum. The smooth side of the belt goes against the drum. Re-attach all the parts in front. Remove the belt access panel on the rear of the dryer on the bottom right side facing the dryer to arrange the belt around the motor pulley and tension roller.
Aug 21, 2009 | Maytag Dryers
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer
there iws another pully with a spring to rap the belt around neer the motor.this pully puts pressure on the belt.
Aug 19, 2008 | Maytag Dryers
I believe the belt on my maytag electric dryer model LDE412 is going out. How to I get to the belt to remove it for replacement? Through the front of the dryer or the back?
Remove the front panel(s). and you will be able to remove the top panel, which will give you access to the top of the drum and be able to replace the belt. There should be a small pulley at the bottom of the dryer where the belt attaches to, as well as around the entire drum.
Jul 03, 2008 | Maytag Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
MAYTAG DRYER LDE4914ACE BELT CHANGE
The belt goes around the pully so that the pully tension takes the slack out of the belt. Just like the serpentine belt on your car.
Nov 15, 2007 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
1,011 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
