Question about Canon Rebel XT / EOS 350D Digital Camera
Close Flash On Xti
I recently just bought a XTI. I started to take pictures and turned off the camera. I want to close the internal flash, but it just wont close even if i push it down. How do i close the internal flash even when its off ?
  • 36 Answers
Turn off the camera and remove the batteries. Then try to close the flash by pushing it down lightly. If it still won't remain closed, your camera is faulty and you should bring it back for a repair/replace.
Hope this helps,
/Chris
Posted on Jan 19, 2009
I just bought a canon rebel xt and I have been playing around with settings I am very new to photography. As of right now when I try to take the shot the flash keeps blinking and its says busy and it wont...
It sounds like you might be too close to whatever it is you're trying to take a picture of. Each camera lens has a minimum focus distance listed on it that determines how close you can get to something and still take a picture. Page 45 of the XTi manual talks about minimum focusing distance and describes the camera's behavior.
It's also possible that there is not enough light for the lens to focus. In this situation you might have to flip the switch on the lens to manual focus to take your picture.
So, either try moving further away so the lens can focus or use the manual focus.
In case you are interested, here is a website that discusses the minimum focus distance. Even though the website talks about Nikon cameras you will still be able to use the information.
Also, on page 160 of the XTi manual there is a section titled "When Autofocus Fails" that will give you an idea of what your camera is doing.
Cheers and good luck. :)
Mar 25, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
With my Canon EOS digital rebel xti i have the
I think it got exposure problem so need to adjsuted exposure and shutter speed or need to replace either top cover or finder unit i recommend to repaire with canon authorised centrre only.
Jul 02, 2010 | Canon Digital Rebel XTi 10.1MP Digital SLR...
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I just bought the 430ex II flash and it won't fire on my Rebel XTI.... i read the manual but I'm not sure whats wrong, have any advice?
I assume that flash is turned on. 430ex flash will fire automatically only in AUTO mode. On manual modes you mus manually force the flash to fire.
If flash doesn't fire at all, consider to claim the vendor or let the vendor to check the flash mounted on your camera.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I have a canon rebel xti with an 18 to 55 lens .. I recently bought an external flash to sit in the hot shoe .. now when I removed the flash from the hot shoe .. the cameras own flash will not pop up and...
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Dec 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon XTi built in flash
With the flash in the up position and looking at the flash housing, there should be a small, metal hook. Make sure it's not bent or distorted. I should be straight and spring loaded all the way towards the front of the body. Check for freedom of movement also.
Aug 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Xti and Speedlite 200E
The only way to solve the problem I see is to turn the flash into non-TTL one. It can be easy done by opening four screws at the connector side of the flash, unsoldering or cutting the BROWN line and closing the connector back. The AF assist led will work.
That I did on my 200E with Canon 400D camera and all works file.
Enjoy!
Jan 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
