Question about Behringer Pmp3000 16 Channel Audio Mixer
Power supply cooked
I have a behringer UB1204FX-pro eurorack. I got it used and the power supply is cooked. Do you know I could buy one or get it repaired. The behringer place charges 110.00 a hour.
Help please
M Clark
  • Edgardo Reyes May 18, 2012
    To get parts ,, Contact MUSIC GROUP SERVICES NV INC at 425-361-3596.
    Music Group is the mother company of MIDAS < KLARL TRKNIK < BEHRINGER and BUGERA.
  • Behringer Master
  • 5,603 Answers
There isn't anything in the power supply you cannot rebuild except the transformer.
BUT you should verify that something in the mixer didn't short out and damage the supply.
After you relace the smoked parts (likely the TOP245Y offline regulator chip is gonzo... then you use this trick to restart the unit safely:
Put a 60 Watt light bulb in series with the hot side of the input power line. I would recommend you use an ISOLATION transformer when working on the power line side of this for safety.
Posted on Apr 26, 2010
  • 4 Answers
Call Music- Group Services NV Inc at 425-3613596 to get the original parts.
Posted on May 18, 2012
Behringer eurorack mx 1604a
36V center tapped plus 48V phantom power, this is, 18-0-18VAC plus 0-48VAC transformer, this should be the correct voltages...
Sep 20, 2013 | Behringer Music
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
I have a behringer eurorack ub1204fx hooked up to a bose L1. I can't seem to get the reverb to work
you have to set three gain controls to pass the FX into the mix. The FX send gain for each input channel, the FX fader which sends the FX mix to the effects unit, and finaly the gain that sends the FX output to the mix. Depending on which effect you choose, some are very subtle.
Aug 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Hi, I have a EURORACK ub1204fx and this is my problem: the effect does not work when I open fx return, there is much noise. Dpm5 broken?. How to get it? Thanks
This is confusing... the "FX return" is for an INPUT from an EXTERNAL effects unit... if you try to take output from there it will be nothing but noise as you are tying two inputs together with nothing driving them. Possibly you are misunderstanding the terms and use of these connections.
Jan 03, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Dec 15, 2009 | Behringer Music
AC POWER PACK BLOWN
David,   I dont like to be the bearer of bad news, but Behringer dissolved its service/repair center years ago.  In my opinion, this indicates little faith in the profitability of servicing Behringer products.  If the manufacturer wont even repair their own products, I wouldn't buy or use that brand if I had a choice.  Their products are good, WHEN THEY WORK.  They keep their prices low by using inexpensive, disposable quality components.  Most of their products aren't worth repairing.      Here are a few options to find your power supply.  Try Rogue music in New York, NY.  Here is the web address.
www.roguemusic.com
Here is another resource.  DBM pro Audio is an authorized Behringer Repair Center.  They are also in New York.  They will be able to tell you if your part is available from Behringer.  I'm very sorry to inform you of the inferiority of Behringer products.  I think the truth, though it hurts sometimes, is the best teacher.  P.S. if you ever visit DBM... next to the elevator, outside DBM's office is a one yard dumpster, it is always brimming with the carcasses of unrepairable Behringer mixing consoles.      Remember, when buying electronics, you get what you pay for...cheap price = cheap components (and usually headaches down the line) Good luck!  I wish you success on finding your power supply.  Michael Mittelsdorf
www.dbmproaudio.com
See my profile for my qualifications. DBM does all my electronics repair.
Jan 09, 2009 | Behringer Rx 1202fx 12 Channel Line and...
Behringer Pmp3000 16 Channel Audio Mixer Logo
579 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
