Question about Kodak EasyShare Z740 Digital Camera
Camera starts, then immediately shuts off
Not a battery problem, checked that. It has been doing this since someone loaded the card onto a computer to get pics.
kodak easyshare z740
  • 2 more comments
  • Anonymous Jan 25, 2009
    Same thing. Comes on for about a second, then shuts off. It's not the battery because I used an external DC source to be sure.
  • russ131 Feb 01, 2009
    wow. we just started having the same problem this week, too. Called tech support, got the new (expensive) battery suggestion. Purchased the new batteries, still nothing... hope someone can help!
  • Anonymous Feb 09, 2009
    Hi, yes i have the same problem. Rechargable batteries used to be ok but now only take about 2 pics. normal batteries do last a little longer.
  • Anonymous Feb 27, 2009
    Thank you for posting, Canoesailor.
    Here's my question: How do you erase the photos on the built-in memory? My camera is only on for one second. Can you take the card out and erase it somehow? I'm hoping that I can bringi it to a place like Walgreen's and erase it there.
    Thanks,
    ept
I took out the card.
Erased the photos on the built-in memory (after making sure they were copied to my computer.)
Replaced the card.
Voila!
Took some photos and it turned off when I wanted.
I wonder if it will last, or if it is a fluke.
Try it.
canoesailorjoe@yahoo.com
Posted on Feb 27, 2009
  • canoesailor Feb 28, 2009
    Canoesailor again, troops.
    The problem came back, but not as bad.
    So I bought Lithium batteries, took a bunch of photos, and everything worked well. On the advice of the camera pro, I removed the batteries until today. The camera will **** the life out of the batteries even when it is "off".
    Replaced the same batteries, and did plenty photos.
    For my Z740, I think the biggest factor is keeping very fresh Lithium batteries on hand. With them, it all works. Without? --- Sorry kids.
I need a usb cable on this Camera my one is broken
If this is relating to download photos onto your computer and your cable and cd are broken this is another way to get your photos onto your computer you can put a sd card into the computer,."sd slot" .go to my computer find the icon that says sd card click on that and it will open it up for you.. .
Jan 24, 2013 | Samsung Digimax S630 Digital Camera
Canon a630 turns on then shuts down
1) press the power button for a moment
2) confirm that memory card is securely closed
3)batteries loaded in wroing directin
4) batteries ARE not the same right type , use only alkaline or NImh
5)insufficiente battery voltage.
6)poot contact between camera and battery terminals.
7) if this DOESNOT resolve the problem you must go to the repair shop service, some short in the SYSCOM and circuit associates are faulty.
God bless you
Sep 22, 2012 | Canon Cameras
My Kodak easyshare c1530 shuts off every time I connect USB cable to download photos. Battery is fully charged and camera works fine until I attempt to download photos..shuts off immediately once cable is...
Try not connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
Mar 13, 2012 | Cameras
I'm trying to load my pictures onto our iMac computer, and my camera says "communication error". I've never had this problem before, and have always been able to load pictures just fine onto our...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you an use iPhoto or any other photo cataloging program.
Dec 31, 2010 | Canon PowerShot A590 IS Digital Camera
My Nikon Coolpix S8000 will not turn on. I started using it for the first time this morning and took about six pictures with it, then I removed the memory card in order to upload the pictures onto my...
Make sure you insert memory card correctly, when it is fitted into the memory card terminal it give clicking sound. Second thing you can check battery, Direction of your battery might be wrong (+,_), Check out and put it again. Load new or fully charged battery. Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
Else your camera need to be repaired.
Thanks...!!
Rating the solution is highly appreciated.
Sep 12, 2010 | Nikon COOLPIX S8000 Digital Camera
How do i load oictures onto my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 20, 2010 | Vivitar ViviCam 5100 Digital Camera
How to load canon ixus 8015 onto my Mac
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
May 17, 2010 | Canon IXUS 80 IS Digital Camera
My camera is saying card not initialized after I downloaded the card in my computer and then placed it back in my camera...
If I understand correctly, it sounds like you loaded something (probably images) onto the card on your computer, then you placed it in your camera.
The problem may be resolved by observing the following:
1. Use your camera to format the card (be aware that this will erase all data on the card.)
2. When loading data onto the card from a computer, observe and do not alter the folder configuration created by your camera.
Dec 30, 2009 | Fuji FinePix 2650 Digital Camera
How do I download pictures onto my computer
To load your digital pictures onto your computer, you will need a card reader (hooked up to your computer via a USB) and your memory card. Some cameras allow you to hook a USB right into your camera without removing the memory card.
If required, you will load your memory card into the card reader. Your digital media will appear as another drive on your computer. Click the drive and your photos will appear in a folder on the drive. You can view your pictures immediately by double-clicking the file. From here, you can save your pictures directly to any folder on your computer.
Additional notes:
  • Consider purchasing photo manipulation software like PhotoShop or Fireworks. Use this software to fix common photo problems (poor light, etc) or add effects like text and color.
  • Print your photos on photo paper.
Sep 22, 2009 | Cameras
Nothing on screen
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. it is complex you need to send it to the service center.
Dec 14, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
206 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
