Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-Air JCD2290HEB not working
This refrigerator was purchased in July 2005 so it is almost 5 years old.
This morning I noticed that my fridge was not working. Both the freezer side and fridge side were warm. There was power and the fan seemed to be running. Six months ago I had a similar problem and the problem was fixed by replacing a faulty evaporator fan. That time the panel in the freezer was cold, there was just not cold air being distributed. This time the back panel inside the freezer half was warm top to bottom.
I took the cover inside the freezer off and confirmed that the evap. fan motor was working. It was. I then went and tripped the electirical breaker for the house off and on again. The fridge seems to be cooling again. Is this indicative of some sort of compressor start-up problem?
  • 27 Answers
SOURCE: jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
Posted on Feb 23, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
eagle338
  • 4889 Answers
SOURCE: Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Posted on Sep 27, 2008
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
heatman101
  • 43501 Answers
SOURCE: We have a Jenn-Air refrigerator Side by Side,
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
What is the manufacturing date for a
What's the serial number, as the date is in the serial number.
Jul 31, 2014 | Jenn-Air Refrigerators
8 year old regrigerator with bad compressor
Make sure it's not your start relay thats attached to the compressor.
Well if you are extremely handy you can purchase a new compressor and install it yourself.
Aug 01, 2009 | Jenn-Air Refrigerators
Compressor is out on Jenn-Air model JFC2089HTB
CALL WHIRLPOOL (THEY JENN AIR) 18002531301 ASK FOR POLICY ADJUSTMENT SEE IF THEY WILL COVER REPAIR
Dec 14, 2008 | Jenn-Air JFC2089HTB French Door...
JCD 2389 GES Not cooling
Yes. I would suggest the control board is possibly damaged.
Model jcd2389ges JENN AIR SIDE BY SIDE REFRIGERATOR Parts
This is not the only place to look, but it is where I would start.
Dec 19, 2017 | Jenn-Air JCD2290HES Side by Side...
Jenn-Air JCD2289AT side by side
air damper closed? try to open it by hand.
Sep 27, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn Air 48" Built In Not Cooling
We just had a repairman out for the same exact problem. What he discovered ours was is that the lights intermittently stay on with the door closed. Test yours like this. With the door open, push the switch that switches it off and on off and on several times. Chances are you'll see that even with the switch depressed the lights are on. If that's the case he says it's one of the relay boards. There are four and the repairman will need to check to see which it is. Hope this helps. If this is the case for a temporary fix you can open the freezer door slowly close the fridge door while peeking through the crack to make certain the light is off.
May 15, 2008 | Jenn-Air 48" Side-By-Side Built-In...
Jenn Aire side by side - freezer and fridge not working
Yes the compressor could be stuck but it's also possible the PTC could have failed - each will show the same symptoms. If you're a tech you can check the compressor or you can just replace the PTC also known as "relay". Part # 12002784 should run somewhere around $60.
Dec 30, 2007 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
96 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
