Hi, I have a durabrand 80 watt, 5.1 surround sound, and am trying to hook it up to my bell express vu sat remote, but cannot with out the code, this brand is not listed in the bell express book of codes, and even when I try scanning through other codes, it is not found. I have misplaced my book for the surround sound and was wondering if you could help me in finding a code. Thanks
this sytem is unable to go past 50 and because its only 80 watts it wont get louder.
80 watts is divided by all the speakers
so a 5.1 system gives 20 watts to the woofer and 15 watts to each of the other 4 speakers.
plus its in rms (root means square)
which means you loose some wattage in fricton so take another 25 to 50 % of the wattage.
so all this said you get what you pay for.
Considering that none of the so-called 'universal' remotes really are, I would guess 'no' and this remote was designed for a specific system so your chances are even slimmer.
Before buying ANY 'universal' remote, check the remote mfr.'s website for a code list for the specific model you intend to buy and make sure that the devices you wish to control are included in that model.
If you don't do this in advance, you will likely be disappointed.
The code lists are 'burned' into an IC in the remote and the only type that can accept new code sets are the 'learning' remotes and they do a lousy job; I own one of these and it will not accept input from either of my later TV set remotes.
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Press the tv and hold it until the red light flash , then press code search , press channel up until your tv goes off , press record and that it your done . Will work for your tv but maybe not for the express vu receiver , this way of finding code makes the remote trying them all so if it dont work on your express vu remote , no other codes will .
I need the remote code to progam it into the cable remote
