Question about APW Wyott AT-Express Conveyor Toaster
Have a apw wyott conveyor toaster, conveyor randomly stops
Wish i could say when the problem happens but its very random. it suddenly stops moving. i have shut it down for a min or two then turn it on and adjust the speed to be higher and it will suddenly start moving again. its been down now for almost an hour and thats the first time its been so long.
I had a similar problem I changed the Rear Bearings in the belt & Check the Fan motor in the rear which houses the conveyer Motor wheather it is working or not it could be the fan not working and over heating the motor the last thing is the screws that hold the conveyer motor are too tight as the motor is self adjusting.
Posted on Feb 05, 2009
I have a apw wyott eletric hot plate model chp-1a. Lately, it keeps on tripping the circuit. Can any one tell what's wrong? thanks. tt
If the breaker trips immediately when you plug it in, then you have a short in the power cord. If it trips when you turn it on then look for a short at the switch or the burner element. If it stays on a while and heats up then trips, it could be a fault inside the element or possible wiring connectors that are not good and tight. Look for discoloration in the wires and connectors.
Aug 04, 2013 | APW Wyott CHP-1A Champion Single Open...
Apw keeps blowing circuit
It may be time for a new toaster, this one could be dangerous. It appers to be drawing lots of current, which would could mean a short inside and could cause a fire.
Aug 20, 2012 | APW Wyott XPRESS (120V) Conveyor Toaster
Apw gas grill causes black suet
All indications are there could be an issue with your burner(s). Check for a blue flame. If the flame is yellowish, there's an issue with air/gas mixture. This would tend to cause flare ups and scorch the food. A thorough cleaning of the burners should resolve this (see attached youtube video)
Also, check all surfaces for any residue grease. Left over grease will burn hot and create the soot you've described.
Sep 26, 2011 | Apw Wyott Ggt 36H Thermostatic Controlled...
I was in military school back in the 1970's , and we had conveyor toaster ovens , and was wondering where i could get my hands on one .
Hello bretrett. These are commercial toasters, often requiring a 220 volt outlet. They are common items, available new or used from most any kitchen supply store. Check in the yellow pages. Joe
Apr 15, 2011 | Holman QCS2-500 Conveyor Toaster
Machine operates very well, except the on / off switch burns out every 4 -to 6 weeks. Is there a replacement wire or special switch I can purchase. Our local suppliers are also puzzled by the problem -...
In replacing switches, you must check if the ampere rating is sufficient to carry the load. Burned switches are usually due to under rated switch or loose termination of wires.
Apr 14, 2011 | APW Wyott AT-Express Conveyor Toaster
I have a APW WYOTT XPRESS CONVEYOR TOASTER several years old. When I plug it in and hit the one switch, there is a short in the unit that causes the GFI to blow immediately. Could the problem be in the...
i just had the same problem, it was the power switch, i re routed wiring to bypass bagel switch and it works fine, but you will want to replace those switches as they a junkily made and the heat destraoys them every couple years
Aug 10, 2010 | Holman QCS2-500 Conveyor Toaster
My "t" and "y" key randomly will not type
You could try using compressed air to move your lunch and dust/dirt from under the keys
Sep 05, 2009 | HP Pavilion dv6000z Notebook
APW Wyott AT-Express Conveyor Toaster Logo
269 people viewed this question
Top APW Wyott Kitchen Appliances - Others Experts
Irene Tulloch
Are you an APW Wyott Kitchen Appliances - Other Expert? Answer questions, earn points and help others
