Unable to log into a Trendnet te100-ps3plus print server
I purchased this unit on ebay and am unable to set it up due too the unit asking for a password which I do not have. Their is no reset button on the print server.
please help.
Joe
  • 1 more comment
  • Joe Muschar Jan 29, 2009
    Thanks for the response however as stated their is no reset on this unit. I also tried the default password as well as SYSxxxx with xxxx being the last four digits of the mac address. With no sucess.
    Thanks
  • alacartes May 04, 2009
    Same problem here !!!!!!!!!!
    bought 2 used print server TE100-PS3plus from RedFrog Networks on ebay but when I tried to configure them they ask me to enter a password and I don't have them.
    Could you let me know how to override the security or reset the password.
  • Michael Lucas
    Michael Lucas May 11, 2010
    on the back there should be a hole to stick a paper clip or a pen into to reset.
    The default password for the device is
    username > admin
    password> admin
There is a utility that you need to access the server. Your firewall has to be off. The link here:
http://www.trendnet.com/downloads/list_subcategory.asp?TYPE_ID=30&SUBTYPE_ID=150
will give you all of the manuals, data sheets and software for this server. I am going to presume that once you get in with the utility you can reset the username and password. I did not, however, see anything that talked about a reset button, unfortunately.
Posted on May 05, 2009
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
Trendnet te100 HP P2035 not printing
1. What is the exact error message or error code?
2. Have you made any changes to the computer prior to this issue?
I would suggest you to refer the following Microsoft article and check if it helps.
Printer problems in Windows:
for more help visit CBR Tech Solutions
Apr 17, 2012 | Trendware TRENDnet TE100-P1U Print Server
TRENDnet TE100-P11 shows print online but won't print
You have to create an LPR port for it to print successfully.
Download the User's Guide from the following link http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1316
and then follow the instructions from Page 22 to 24
Jun 24, 2010 | Trendware TRENDnet TE100-P11 Print Server...
Attempting to connect with trendnet TE100-p11 print server doesn't work. Trendnet infers it is not compatible with CAPT (Canon Advanced Printing Technology) type printer
Make sure the Print Server has the same IP address as your network. The run the PS-Wizard which is available on the disk. This PS-Wizard will install the printer driver as a network printer. This will let you print without any issues
Feb 08, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
TrendNet PrintServer TE100-P1P does not print
I get the same error connecting to an OfficeJet K60. Have been successful with my Macs, but not with XP.
Jul 08, 2009 | Parallel TRENDnet TE100-P1P 1 Port Print...
HP 1018 printer
try this: right click printer, go to tab Ports and check Enable bidirectional support it works for me .
Aug 10, 2008 | Trendware TRENDnet TE100-P1U Print Server
Trendnet TE100-P1U won't print
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
Mar 31, 2008 | Trendware TRENDnet TE100-P1U Print Server
LaserJet 1600 offline status
Is the print server being assigned a IP address in your network?
Mar 05, 2008 | Trendware TRENDnet TE100-P1U Print Server
Printer is offline ever
I would suggest you one option if the operating system is windows. You have to go to Start -->Control Panel --> Printers and Faxes . Then you will see your printer icon there. RIght click on that. Check whether you are having an option "Use printer Online" or "Set printer Online". If you have that option , just click on that and apply the settings and see what happens - Thank you
Oct 25, 2007 | Trendware TRENDnet TE100-P1U Print Server
Computers & Internet Logo
1,406 people viewed this question
David Payne
David Payne
