Question about Danby DMW1153 Microwave Oven
DENT MICROWAVE IS IT SAFE TO USE A DENTED MICROWAVE. JUST THE CASING IS DENTED
    Genius:
  • 1,199 Answers
As long as the door seal is not bent or broken it is safe to use!
Please rate this free response!
THANK YOU!
Posted on Jan 17, 2009
How do you access the door switches for the microwave.
doesnt that mean the door itself is no longer safe
and leaks like a chernobyl when operating
risky DIY
if not an electrician sometimes better to buy a new microwave
most microwaves
take the outer casing off
then its a lot of electrical things to unplug. unscrew
May 19, 2016 | Microwave Ovens
Keypad not responding
Make sure none of the keys are stuck if a mechanical type like a computer keyboard or scratched or dented if a film type keyboard.
Make sure the door is closed completely.
If still not working, unplug the microwave from the oulet for 30 seconds or more to allow any internal microprocessor to be reset, then try again.
That's about the extent of what an end-user can do get the keyboard to work again. If still not working it should be brought to an appliance repair shop for service.
Jan 03, 2013 | Samsung Microwave Ovens
My murphy richards microwave door release button has snapped can this be repaired & how do i do it ?
change the front panel door casing or the entire body shell, to be on the safe side.
Dec 27, 2012 | Microwave Ovens
I thought my plate was microwave safe, Well I was wrong lol. It melted to my microwave, is there anything I can do or do I have to buy a new one? It was one of the expensive rotisserie microwaves that...
Hi.
First try to scratch out the plastic from the surfaces inside the microwave cavity. If that is not possible you will need to replace the parts. Most parts for microwave, including cabinet and casing are available from part sellers. Below a website showing several part sellers. If they do not find your model find a local part seller and call them. You can ask an exploded view of the part needed if you want.
If you need parts or diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
After disassembly and repair the microwave must be go through a standard radiation leak test, hence the job is better done by a technician.
Regards.
Ginko
Sep 15, 2011 | Microwave Ovens
It is not starting
Many possiblities, but first thing to check is door switch. Unit will not run if door is not closed. Door switch is safe feature. Remove outer casing and check to see if switch is broken or miss alined.
Sep 23, 2010 | Daewoo KOG-867T Microwave Oven
CAN'T GET BULB ACCESS DOOR OFF TO REPLACE UNDERNEATH BULBS
Hello there:
first you need to remove the screws from the back of the microwave that hold on the casing and there might be some on the bottom too. then remove the outer casing
the bulb is under the casing towards the front right corner as you are looking at the front of the microwave
Sep 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Jan 23, 2009 | Danby DMW1153 Microwave Oven
Is my dented microwave safe to use?
Hello carillon553,
If you haven't compromised the door opening or inner compartment, then it is more than likely OK to use. The magnetron ( which generated the microwave energy ) has a waveguide that focuses that energu into the cooking compartment and a small dent to the cabinet normally has no impact on its safety.. Hope that helps..
If you are overly concerned with that, then you would need a technician that has an RF Power Meter to check it.. If it were me, and the dent was small.. I would just use it...
Regards,
Rick
Dec 13, 2008 | Danby DMW1153 Microwave Oven
KitchenAid KCMS185JSS1 Door Removal
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Mar 12, 2008 | KitchenAid KCMS145J Microwave Oven
Danby DMW1153 Microwave Oven Logo
312 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
