Question about Canon Optura 500 Mini DV Digital Camcorder
Canon optura 500
How do you use an external microphone? I have a couple I've tried plugging into the microphone jack, but I get nothing and while it's plugged in the internal mic wont work either. In the display, it doesn't matter if mic attenuation is on or off. Is there a specific kind of microphone you have to use?
    Scholar:
  • 35 Answers
I believe you need a stereo mic. This will have two black rings around the male input. When you plug it into the camera, it will "disable" the built-in mic. I don't believe it will matter if the attenuation is on or off.
Posted on Jul 01, 2007
Microphone
Sorry but only the latest models have a built-in microphone. I've even searched the tech manual for you without success. You;ll have to buy an external mike and plug it into the microphone jack.
May 04, 2012 | HEWLETT-PACKARD HP Pavilion Dm42070us...
No sound in recording. The Canon GL2 camera shows "C" and the microphones are off, as though there is an external microphone attached, but there is nothing extra attached. Tthe WS (windscreen)...
The most likely cause for this is a faulty external microphone input jack. They are designed to disable the onboard mics when an external mic is being used. The switch that acomplishes this is probably stuck closed so the camera thinks there is an external microphone attached. This will require major disassembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 09, 2011 | Canon GL2 Mini DV Digital Camcorder
Where can I get a user manual for Canon camcorder Optura 500
You can download the user manual for this unit from this link, just click HERE.
Sep 26, 2011 | Canon Optura 500 Mini DV Digital Camcorder
Hi I am using a HP PAVILION running on windows xp operating system and it cannot detect any microphone i plug into I've tested the microphones on other computers and they work please help i tried to...
either the jack is damaged or the microphone is just not enabled.
use this as a guide http://www.tinyeye.com/avsetup/soundsetup_xp.html
this will show you how to check all this information.
if the guide does not work then next you would format your pc to make sure there is nothing else causing it. not a system restore a full format.
if that does not fix it then you have a damaged jack and you can get a usb microphone to do the job.
Jun 29, 2011 | HP Tablets & eReaders
CANON OPTURA 500
Were the battery goes there is a cover with a silver screw holding it on. There is a flex behind it that sometimes comes loose and causes the problem you have described. Remove the screw and cover and push on the part behind the cover. I work at canon and when we get a model like yours that usually is he problem.
Dec 31, 2008 | Canon Optura 500 Mini DV Digital Camcorder
Canon optura is not connected to my pc
make sure you are using firewire only-not usb-if you are using firewire the computer should recoginize the camcorder as soon as you plug it in
May 08, 2008 | Canon Optura 30 Mini DV Digital Camcorder
How to record with dates
you shoul really need to look at the instructional functions of the can corder . simply look for the settings for you to get the right file
Mar 13, 2008 | Canon Optura 500 Mini DV Digital Camcorder
My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Feb 12, 2008 | Toshiba Satellite A135 Notebook
Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Mar 17, 2007 | Canon Optura 50 Mini DV Digital Camcorder
Canon XM2 -Audio Trouble
hi first: http://www.fixya.com/user-guide/p394384,m11809,gm57/Canon-GL2-Mini-DV-Digital-Camcorder.aspx yes you need to connect to the input jack: http://www.fixya.com/user-guide/p394384,m11809,gm75/Canon-GL2-Mini-DV-Digital-Camcorder.aspx if it wont work there is probeblya burned capacitor from the boosting good luck
May 05, 2006 | Canon GL2 Mini DV Digital Camcorder
Canon Optura 500 Mini DV Digital Camcorder Logo
77 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
