Question about GE Profile JTP18 Electric Single Oven
Trying to change oven lightbulb and sparks flew
Unscrewed light dome to get a grip to remove the cover and change burnt out light bulb. Sparks flew and now there is charring down the side. I still cannot remove the cover. Any help would be greatly appreciated.
2 Suggested Answers
  • 23 Answers
SOURCE: GE JTP20 oven. Do I need to replace light fixture after spark from a short?
First, no First, no First unplug the range after you gently scoot away from wall. Then check youy main circut breaker for house to see if you tripped fuse. Then with stove still unplugged remove back access panel, look to area where light goes into oven. Check again and make sure oven is unplugged, then repair the wire by splicing wire with new wire line splice purchased at your nearest local auto parts store, sales person can show how to install. THEN plug in to see if you can see the light!
Joe Don
Posted on May 25, 2012
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
Where is the lightbulb In the oven and how do I change it?
Hard to give you exact location with brand or model number but here is what you look for. Open the oven door and with a flashlight look over the top and back wall of the inside liner. The light bulb is usually located behind a clear glass round cover. The cover may have a wire retainer across the middle of it to hold the glass. If it does, just flip or push the wire to the side and the glass cover will come loose. Unscrew bulb to replace. If no wire retainer, then there could be a metal plate with screws holding the glass in place. last type would be that the glass itself unscrews to get to the bulb.
Apr 02, 2015 | Ovens
How do you change the oven lightbulb?
Most require 2 screws to be removed to lift the glass cover from over the bulb. Then simply unscrew the bulb and insert new bulb. A 1/4" nut driver is the best tool for the job.
Sep 08, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
I have recently moved into a Park Home that has a 4/5 year old Candy cooker - the light bulb in the oven has failed and needs changing, but I cannot mov e the glass cover at all, it will not lever/unscrew...
If it has not been removed for a long time, then it could be stuck with bunt on grease and fat.If it is a round glass, then it should unscrew anti-clockwise.
Try wrapping a cloth round a pair of grips, and try to unscrew it that way.
Do not put too much pressure on, as you may break the glass.
Feb 08, 2010 | Candy FP855 Electric Single Oven
How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Nov 07, 2009 | Ovens
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Whirlpool Super Capacity 465 oven can't figure out how to change the lightbulb and it is not listed in the owners manual. Can anyone tell me how to remove the lightbulb cover?
The glass lens cover for the bulb is usually screwed into the socket so turn it counter clockwise and see if it comes off. When replacing the light bulb, press the door switch to ensure no power is going ot the bulb socket to prevent it from damaging the new bulb.
Mar 07, 2009 | Ovens
Unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Jan 12, 2009 | Ovens
Can't figure out how to change the light bulb in the oven
normally the cover just unscrews but may be difficult if not removed for a long time - large pair of grips will help
Nov 25, 2008 | Ovens
GE Profile JTP18 Electric Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
