I have a canon pixma pi1800 i will not take the paper... it keeps saying paper jammed!! i tried cleaning rollers etc... tried printing a test shhet.. it says printing finished but i hadnt done it as it didnt take the paper, i van hear it working....
  • sues_shaw Jan 17, 2009
    ok thx i will try that, i have lost the cd to download sortware.. went on canon site n downloaded another one.. its a new comp but been in the cupboard and not used for ages, it has new ink.. rollers run ok, checked that.... i will give you advice ago.. thanks
    done all that, its still not taking the paper down, it takes is so far and stops and sats paper jammed... the paper grabber thing takes it down so far... the priner is printing, i can hear it and ink is being used....
  • 1,029 Answers
Here's a few things to try :
1. Blow it out with compressed air blower .especially the rollers and the paper feed area make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
after plug it back if the problem still persists then move to the next step
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.hope this helps
Posted on Jan 17, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 17, 2009
    ill appreciate a fixyaa rating
    Starnley Johnwells Jan 18, 2009
    examine all rollers as the printer starts ,there must be some stuck on the rollers check all the rollers properly and try moving them manually by hand and observe,if they all moving then use a sand paper to put in between the rollers move them to give it a rough edge incase the rollers are worn out
Says I have a paper jam when there is none
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper roller on the left side of printer will not feed the paper
Hope that helps!
Aug 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper jammed
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq23
Jun 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Dec 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Printer always prin at the to of the page and then it will parer jam but no paper is in it to jam up I have a canon bjc-4200 and I like the print that it dose
hi there,
This problem mostly caused by another material (such as broken paper, etc) present in paper path prevent paper to reach paper cam sensor. Check inside your printer and clear paper path from another material. You can also try to clean paper feed roller. If problem still persist, replace paper feed roller
Regards
Source:
Canon Inkjet Forum
Nov 09, 2008 | Canon PIXMA iP1600 Printer
"Clear paper jam" error, but there is no jam!
hi,
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
74 people viewed this question
