Question about Garden
NO START I HAVE THIS STIHL CHAINSAW (MS460) THAT I CAN'T GET STARTED. I'M CONCERNED WITH THE IGNITION MODULE IS WEAK & NOT PRODUCING A STRONG ENOUGH SPARK. IT HAS FUEL, COMPRESSION (NOT THE BEST) & SPARK. ANY IDEAS WILL BE HELPFUL. THANX GALE
    Problem Solver:
  • 11 Answers
1. has it been sitting?
2.if yes dump out the old gas and what is premixed since it is possibly old, 2 months max.
3. new prem gas and oil mix.
4.press the comp release when starting , was this pressed when you checked compression?
5.if will not sart try a quick blast of WD-40 in carb or a little gas. WD is flammable and will let you know if fuel related. if it fires for a couple seconds then sparks ok and still has gas problem. try one more time and maybe stuck fuel pump flaps in carb will become unstuck. if it runs on WD or small amount of gas in carb but not otherwise, sparks OK. time to rebuild carb check filter and Gas Line.
As always when playing with gas or other Flammables have a Fire Extinguisher ready for the "Expected". Always expect a fire that way you are calm, VERY important if you have spectators.
Safety Guy Bill
Posted on Jan 17, 2009
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
017 Stihl chainsaw problem
Could be the spark isn't as strong as you think it is. Could be the spark weakens when the unit is warm. Electronic module ignition needs an energetic pull at the best of times to get a strong enough spark for starting and if it is weaker it would be impossible to pull the starter cord fast enough.
Instead of testing the spark with the standard spark plug try using a spare plug with the gap opened to about 1 to 1.5 mm. The atmosphere in the cylinder during compression is much more dense than in open air and a much stronger spark is needed to jump the gap.
If the spark is satisfactory it could be the crankcase compression that is low, perhaps leaking past the crankshaft seals. If the chainsaw is little used and stands idle for longish periods this could be the problem. Seals tend to lose flexibility quicker under those conditions.
Mar 26, 2016 | Stihl Garden
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
I have just replaced the spark plug, fuel lines,brand new carby, and new ignition module, but will not start. any thoughts. It is a Stihl FS85 BRUSHCUTTER. Thanks.
I had the same model and always had a hard time getting it to start after taking it to shop it started three times ok then the hard to start all over again. It now is in the trash as I refuse to put any more money into it. Stihl makes a great chainsaw but I would never buy another trimmer or brushcutter from them again.
May 16, 2014 | Garden
Stihl 066 does not start. Replaced ignition module. Weak or no spark.
Are the poles on your flywheel blue? Are you using an open-air inline spark tester, or holding the plug against the cylinder and turning it over?
Jul 14, 2012 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
How do you start a STIHL MS460 chainsaw
I am a Stihl mechanic. The proper starting procedure is to set the switch to full choke. Pull the starter rope no more than three times.Now raise the switch up one notch and pull it till it starts. Stihl products will flood if pulled more than three times with the choke on. Thanks, George
May 08, 2012 | Stihl Chain Saw Handle Models 044 046...
Having trouble finding how to start the ms460
Hold the trigger and move the lever on the left all the way down -you know what? if you can't figure out how to start a Pro saw like a 460, you shouldn't be using it at all.
Garden Logo
274 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
