Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will not work in cold weather.
I have a Craftsman 3/4 HP door opener. It is less than 2 years old and in cold weather (Less than 40), when you hit the button, the light will flash but the door will not rise or lower. I live in Dallas and it does not get severly cold, but this is the second winter that this has happened. Once the temps get above about 40, the door works fine. Please help.
Robert Gordon
  • 1 more comment
  • ghomeghome Jan 18, 2009
    Thank you for the information. I will try to make the adjustment. I notice that it is set on the lowest (1-9). Of course it is warm today so I may have to wait a few days until it gets truly tested.
  • ghomeghome Jan 24, 2009
    I waited until the next cold snap and tried the adjustment. It didn't work. I tried it at a setting of 3 (out of 9) and then worked it up until I had it at the highest setting. The door still will not close in the cold weather. I am stymied. Thank you for trying.
  • Anonymous Jan 24, 2009
    I had the same problem with the cold and the garage door not closing. What I found that works is holding down the button to open and close the door. If I do this - the door will either open or stay closed when I let my finger off the button. Try this and see if it works for you.
    Champion:
  • 244 Answers
Leave car outside. Seriously, try a little more force to force adjustments.
Posted on Jan 17, 2009
  • marty metzger Jan 24, 2009
    does it close manually ok? Try checking rpm interrupter cup. Is it push on tight (Behind logic board, take off 4 screws, tilt board and push on black cup).
I have a problem with the hand held remotes working on my garage door working
Look at the opener to see if you can see the small wire dangling form it. That is the antenna. Stretch it out and point it down for maximum range.
Aug 18, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
On down door reverses in cold weather
A garage door guy says that in colder weather the weather stripping can become stiffer, less pliable, causing more drag or friction on the door. You may need to increase the down pressure a bit. If it's set in the normal range, try increasing it a little bit at a time, but don't max it out.
Dec 26, 2012 | liftmaster Chamberlain Garage Door Opener...
I have a 1/2 hp Sears Craftsman Garage Door opener about 18 months old when operating the remote within 5 feet or less of the opener the opener works properly. Upon exiting the Garage about 10-12 feet away...
The difficulty is determining if your remote or the receiver is bad. If you have another remote that works as it should then it is the remote. If you just have the one remote there is no way to tell which is bad.
Jul 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have two Sears 1/2 hp garage door openers. Cold weather problem
Very strange they both have the same exact problem. I would suspect something with the brackets is changing. When you are having this problem and the light on the receiver unit is not lit, tweak them a bit and see if it comes on. The odds of the logic board in both openers having the same thermal problem is just too high.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont close in cold weather
find force adjustment on logic board and turn clockwise A LITTLE to increase down force. Try to stop door. You do not want TOO MUCH FORCE as that is a SAFETY HAZARD.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 hp craftsman garage door opener won't open when cold
I called Sears garage door customer service number due to the same issue. The test is to disengage the opener drive by pulling the emergency disengage handle, then open the door half way manually and then let it go. If it stays there it is a door/track/lub problem; if it drops down and closes its a garage door opener problem. Mine stayed open half way during this test so it was a door/track/lub problem. After using silicone spray on all tracks, rollers, and springs mine has been working great. Good luck.........
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
630 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
