Question about HP Pavilion dv6000z Notebook
HP pavillion dv6000 power button has trouble working
Over several weeks the on button has become balkier & balkier to start the machine. When we do get it to work the laptop runs normally, but now it seems to have failed altogether. The quickplay will power up annoyingly as ever just by accidentally brushing by the clickless button.
Any good troubleshooting guides for this? Good sources for parts?
If the physical switch isn't the problem what else need I think about? Anything a guy good with tools & delicate parts should leave to an "expert?"
Many thanks.
  • 4 more comments
  • Anonymous Jan 22, 2009
    power button
  • Anonymous Jan 25, 2009
    I'm pretty sure its a bad connection. The same area is where the speakers connect inside the machine. I'm also working on the exact same issue. What I can tell is that we're not alone in the dark on this one. There are a ton of people with this laptop with the same issue.
  • Tim strycharz Mar 01, 2009
    won't load windows xp and power button doesn't work i put a new hard drive in it and now the power button and speakers don't work now what the **** do i do now HP SUCKS
  • Anonymous Apr 06, 2009
    I thought the power button on my HP Pavilion dv6000 was dead. I replaced it and it still didn't work. Did the cable swap and powers up just fine. Ofcourse the Quick play doesn't work anymore but that is something I can live with
  • artsta Apr 16, 2009
    I have the same issue.
    The suggestion: "switch the wires from the quick play to the power button the wires are under keyboard " sounds like a good one, but when I attempted that, I found the wire from Quick Play didnt reach the power button.
    Or did you mean, physically swap the entire wires altogether?
  • ereljo May 25, 2009
    My power button is difficult too... I have to push really hard and jiggle it for the computer to turn on. AND my speakers have not worked for the past 6 months.. the power button issue seemed to come about shortly after the speakers stopped working. I can plug in headphones to listen but that's no fun :o( "They" (lots of different people) want too much money to fix the issues that they haven't even formally diagnosed yet... Does anyone have any suggestions for the thechnology challenged like myself?.. I am not computer literate enough to open it up and switch wires around...
  • 3 Answers
WORKAROUND: until I get brave enough to open the case and fix/swap the cable I use the QuickPlay touch button to start system. I must hit CTL/ALT/DEL when the first HP screen appears which causes Windows to start normally without going through the QuickPlay/hibernate hassle. Hope this helps a little.
Posted on Apr 20, 2009
    Problem Solver:
Switch the wires from the quick play to the power button the wires are under keyboard
Posted on Mar 07, 2009
The solution is to replace the chip that is underneath the power buttom (it runs the speakers too). First remove the battery. Then remove the three silver screws that are underneath the battery (the ones in the middle - not the black ones at the edge). Now flip over the laptop and open it. Use a thin screw driver to pry off the switch cover - start at the sides in the seam next to the esc and del keys. you will see a small green chip on the left side. It is secured to the cover with a single srew. Unplug the wires and replace with a new board (http://www.google.com/products?q=33AT8BB0017&oe=UTF-8&ved=0CBQQrQQwAA&scoring=p)
Good luck.
Posted on Feb 11, 2010
  • jawzporter Feb 04, 2011
    Thanks! Havent had sound for a year and power button has not worked either... and when I use headphones one side was much lower in volume than the other. Thanks again!
HP dv6000 series power button failure (further to thread of 2008):
Has anyone solved this issue? Can anyone provide detailed instructions on how to swap the wires from the Quick Start circuit to the power-on circuit?
Many Thanks
Posted on Dec 01, 2010
    Genius:
  • HP Master
  • 1,102 Answers
Does your power button need cleaned
Posted on Jan 18, 2009
Black screen
Well, if you're bold and don't want to spend a lot of money, here's how I fixed mine...
http://www.youtube.com/watch?v=xRbES2dcvjw
I hope this helps somebody!
Dec 29, 2012 | HP For Pavillion Dv2500 Dv6000 Dv9000 Ac...
My lap top is hp pavillion dv6000 . after 5 minutes I turn it on the fan starts working and about 25 minutes later it turns off by itself as a kind of protection because it gets hotter
Is this Question or Solution?? and about fan.. Usually when you switch on you pc all the hardware gets initialized and after a while when CPU fan or Power supply fan functions on the basis of inside temperature.As per the temp it will become slow sometime stop and again will start??
Sep 18, 2010 | Computers & Internet
Hp pavillion laptop screen goes black
its the common problem with graphic card, if its nvedia chipset graphic, there is only one temp solution, ask any hardware machanics to put a glue and heat the display ic, then it would work for a week, in that period buy the amc from hp service centre, after a week if there is a prob, company will have to replacd the motherboard
Feb 10, 2010 | HP Pavilion dv6000t Notebook
Hp pavillion dv6000 push the start button, lights come on for ''split second'', and nothing. lights go off, no motor, no nothing. happens when plugged in or not
You have suffered a motherboard failure, just to be sure you need to check the voltage at the tip of your AC adapter and leave the system battery out of it, Just try to power it on with the adapter. If the same event happens, you will need to either service the motherboard or replace it. Ebay has several MOBO repair services for the HP products, specifically the DV6000 and the DV9000. These have been HP's problem child for a few years.
Jan 15, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion DV6000 won't start
It's a fabrication defect. For more info about it and free repair see here
Sep 19, 2009 | HP Computers & Internet
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
Wecam 1.3mp builtin for hp pavillion dv6000 found not working the day i bought the machine
Hi I have Hp pavillion dv6000. When am using yahoo msnger or msn ..the web cam not working. There is one message coming Your web cam is not connected. Please give me a solution for this....
Thanks
Simon
Jul 15, 2008 | Computers & Internet
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
6,819 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
