Question about GE Profile WPRE6100G Top Load Washer
GE washer won't fill with cold water
GE top loading washer Model WBB4500E1WW will not fill in the wash or rinse cycles with cold water. I t will fill with warm water. Any advice?
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Have you checked the hose and small mesh filter inside?
  • Anonymous Mar 13, 2014
    no cold water filling the washer
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
Not geting the cold water. Only once and a while even though set on Bright colors
Fixing a Washing Machine with Slow or No Cold Water Fill ...
? 7:40
Feb 10, 2014 - Uploaded by SamuraiRepairman On washers with this problem that do the rinse cycle with coldwater only, the ... Top comments .... It's a front loading machine so I can't open it when it's on. .... GE Washing Machine Repair - Water Overfills, Overflows Washer ...
Aug 09, 2015 | GE WHSE5240D Top Load Washer
Water filling
sounds like a faulty cold water solenoid
Sep 25, 2017 | GE WDSR2080D Top Load Washer
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
1 Answer washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Ge # wbb4500e1ww stops during fill, wash,spin and rinse cycle intermitenly there is no regular pattern we can follow. We are lost as to what to do
Check your hose end. On your hoses there are screens at the end that goes on the washer, and that screen could be plug enough to intermitent.
Dec 07, 2009 | GE WBB4500EWW Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
GE washer
replace the water inlet valve
Jun 10, 2008 | GE WBSR3140DW Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
573 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
