Question about MSI K9MM-V Motherboard
At power up about 50% of the time I get a flashing P/.
When this happens, the MSI flash screen doesn't even come up and the booting sequence goes no further. I then have to power down then back up again.
    Sergeant:
  • 238 Answers
Sounds like the power supply is failing. The power supplies have protection circuitry in them so that when there is excess current draw, the output voltage is 'clamped' (reduced to a lower level) so that the power supply won't burn up. If you are consistently experiencing this, that's a sign. If you added another drive, a new video card or upgraded the processor a little while ago, the power supply might not quite be up to the task. Even with nothing new added, a lot of power supplies don't like to be operated at much over 60@ of their 'rated' capacity, and their ratings are significantly lowered at any little temperature rise.
Posted on Jan 17, 2009
MSI L1600 netbook seems to be stuck in sleep mode. The power also cannot be turned off - even removing the battery and replacing it.
try to boot the computer, if you hear the start up sound then mobo is not bad. this issue could be caused due to boot sector viruses as well. see if the back light turns on ..
check the settings in bios and try to run a recovery. if neither helps
call 1-877-805-1027 for expert help
Jul 30, 2015 | MSI Computers & Internet
Dell E6400 won't boot up (most of the time)
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 11, 2013 | Dell Latitude E6400 Laptop
MRI ER710 only gives black screen after hitting the power button
try removing one by one components and then try to start.
if there's some beep code or flash pattern then do tell !!
that might take long process of troubleshooting..
do contact me to solve it.
Jan 23, 2013 | MSI Micro Star International Computer - 17...
How to reboot from boot sequence
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. You want to boot from the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Dell XPS M1730 Laptop
Windows logon screen flashes for 6 minutes
After the 6 minutes, what happens? Does Windows finally load? Does it power OFF?
Let's assume Windows eventually does load. The problem wouldn't be the monitor, instead look at your boot devices. You "could" have a USB Flash drive installed on your computer and that may affect the boot process. Try removing any external USB drives from your computer and try booting again. If it does load quicker, you have to check the internal configuration / setup screens on your computer. There is a boot sequence or boot order sequence that needs to be altered.
Mar 09, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
My msi wind wont start!!! i was trying to reinstall my windows using the recovery disk, so restarted my wind but mistakenly pressed f12 instead of f11 to run the boot set-up, but my screen froze (totally...
I'd like to help you, but it is very difficult to diagnose based on your description. We will need to gather more info as we try a few things.
1. Why are you reinstalling? 2. How old is the system? 3. Try the following & let me know the result: turn system back on. When the normal LED indicators are on, press & hold down the power button for 4+ seconds until everything goes off. 4. If step 3 worked, then turn power on & hit bios setup key (f2?). 5. See if HDD is detected.
Jun 07, 2010 | MSI Wind U100-030US Laptop
Tv screen goes off and on
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Feb 12, 2010 | Sony BRAVIA KDL-46V3000 Television
I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System...
It sounds as though you might have a problem with BIOS.
You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
Nov 16, 2009 | Intel Motherboard
Boot sequence problem while booting
your mocs cell waltage goes down.
CMOS cell gives power to bios flash memory when it goes to low bios forgot settings after power off.
So purchase new CMOS cell it is on motherbord change it then save settings then it not forgot settings even after power off.
Thanks for using fixya.
Jul 27, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
MSI K9MM-V Motherboard Logo
59 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
