Question about Coffee Makers & Espresso Machines
Display for Krups Beertender stopped working
The display for the Krups Beertender has stopped working. The screen still lights up, but the screen is blank.
Unplug the unit for 30 seconds, then plug back in. I had this problem, and it is a solution to most modern electronic devices. it reboots the system.
Posted on Feb 13, 2010
  • ChicagoRod Jan 27, 2011
    I found a new peltier plate on Ebay for about $6. Supposedly they do go bad and are easy to change. They are located under the fan, under the heat sink (silver thing with fins for cooling). TEC-12705 is the part number.
  • Treacherous Jul 27, 2012
    Not sure if it helps much but I put new CPU thermal paste on there as well.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
This will most likely not fix the problem. The blinking is most likely a over curent issue. if you disconnect peltier plate the blinking will stop. However this indicates that the peltier plate is
bad. This will need to be replaced. It is approx. a $5 part.
mastecutor@gmail.com.
This will most likely fix the problm and save you from throwing this in the trash or sending back to Krups and paying more than you orginally paid for it.
Posted on Sep 10, 2010
  • 1 more comment
  • Pete Mote
    Pete Mote Sep 14, 2010
    Additional Information. Although the Peltier effect plate can go bad I found
    an additional problem with the Krups Beer Tender design. The four
    DC power supply Capacitors go bad. These are 16V electrolytic caps
    3 x 1000uF and 1x500uF. All four of these caps were blown. Typically you can visibly see the camaged cpas. the top of the cap bulges out, leaks in some cases. Replace
    these and the blinking screen goes away and Tender will star cooling once again. Send
    me an email if any questions. mastecutor@gmail.com
  • TheNick956 Feb 05, 2011
    Mastecutor, Thanks for the info! You got me up and running again! Very helpful! Thanks for the time and advice!
  • Julian fisher
    Julian fisher Oct 18, 2013
    I replaced all the capacitors. They were bad. However this did not solve the problem. I am not getting any power on the DC side of the board. Something else is wrong?
Thanks for the info!! You go my B90 Beertender back in operation. No blinking lights and cooling well again. I should have run the oem peltier on a 12V battery to test out whether it was bad. One should do this before ordering a replacement. Oh well...I have two backups of those. They were only about $12.
The fix was the capacitors. The (3) 1000uF were bulged. I didn't replace the 500uF because I was having a hard time tracking one down. It wasn't bulged so I didn't look any further. I bought the 1000uF capacitor replacements here for $1.44/piece.
http://store.stsi.com/eeu-fc1c102s.html
Posted on Jul 27, 2012
Krups b100 does not get cold enough. How do i fix this
Maybe the beer inside is cold enough to drink, but the green led that indicates it's ok, doesn't light on. So the thermostat may be not operating well or the ambient temperature is too hot. My beertender B100 is operating without turning compressor off. The compressor never stops operating... even when external temperature is under 26 C... but the beer temperature is ok.
Oct 04, 2013 | Krups VB2158001K BEERTENDER B100
Krups Beertender VB5028CT (C75) totally dead now.
I had one that appeared totally dead and replaced four capacitors (~$5 to buy) and it's back up and running. If you pull the back of the unit and remove the unit attached to the power cord you'll see a pcb board. Look for any capacitors that look kind of rounded on the top (they should be flat). On mine it was a cluster of one 470 uF and three 1000 uf capacitors. Desolder those and solder in new ones. Mine were rated at 16 volts but I replaced them with 25 volt units for a bit more safety margin.
Jan 11, 2013 | Krups C75 Beertender Home Beer-tap System...
Krups beertender not cooling
Replace the capacitors in the power supply circuit 880 and 470 mikrofarada.
Dec 24, 2012 | Krups BeerTender B95 Beverage Dispenser
I have owned a Krups Beertender for about two years. It has been working fine. The unit thermostat light turned red about 24+ hours ago and mains on. The fan is working. The beer is warmer than usual. ...
It could be the peltier or bad capacitors on the power supply.
http://www.fixya.com/support/t1554764-display_krups_beertender_stopped_working
If it is caps on power supply they are cheap.
Jul 21, 2012 | Krups BeerTender B95 Beverage Dispenser
I have a problem with a Krups Beertender model VB5020us. The indicator lights were blinking sporadically and it was not cooling. I removed the back and found that there are two circuit boards. One is...
If the lights are on/blinking, that usually means that the control board is OK, and it's the power supply that is not providing sufficient power for the cooling element to operate. This is a common issue with the Krups VB 5020 series.
Aug 17, 2011 | Krups BeerTender B95 Beverage Dispenser
Our Krups Beer Tender B95 display started flickering on and off. We turned it off by the switch and back on. It continued flickering. We then unpluggedf it. When we plugged it back in, it totally shut...
Your power supply has gone bad. Mine did the same thing. Sent it to repair place (under warrenty) and it has been 2 months and it is still not back. If you can find another beertender for 100 it is cheaper to buy another OR JUST TRASH IT!!!! Obviously this thing is junk as there and 100's of the same postings of this problem.. fafe it... we got ripped off. Sad because I really liked it... when it worked
Jan 30, 2011 | Krups BeerTender B95 Beverage Dispenser
My beertender stopped cooling my keg. what can I do to fix it?
Wondering if you found a solution to this yet. Mine stopped cooling, too.
Oct 03, 2010 | Krups BeerTender B95 Beverage Dispenser
Beer is not chilling and the display keeps blinking
Let me know what you find out. I un plug the thermastate and it stops blinking. If I plug back in. It starts blinking again. Regardless with or with out it plugged in the unit will
not cool below 66 degree's. I think there isosomething wrong with
the cooling agent or the thermastat
Aug 08, 2010 | Krups BeerTender B95 Beverage Dispenser
Coffee Makers & Espresso Machines Logo
2,148 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
