Question about NetGear RangeMax WPN824 Router
Wpn 824 wireless issues.
I have a netopia cayman 3300 dsl modem connected to a wpn824 netgear router. firtly I could not connect to the internet from a wired connection from the ethernet port of the dsl moden to the internet port of the router. this issue was resolved by connecting the cable from the modem to one of the ethernet ports on the router and another cable from the router to the pc. Now I have setup a wireless connection which communicates a signal with the pc but fails to access the internet.the wep key which I set on the router was 01234abcde and was also set on the pc's wireless card (which is a dell pci card). Please help in trying to shed some light on this matter
  • martin keane Jun 21, 2007
    reolved issue by enabling bridging on the netopia cayman 3300 modem and following the steps on the netgear wireless router.i was able to connect from the modems ethernet port to the internet port and complete the wireless installation ,plus reset the router to its default settings.everything fine now.thanks for your help
    President:
  • 2,961 Answers
If you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Posted on Jun 21, 2007
I'm trying to connect a netgear wpn 824 to a comcast router with windows 7
You are trying to set up the wireless router with the comcast modem, right ?
You can set up the router manually , without the disc.
Make sure that your computer is able to go online when connected to the comcast modem only.
If you have the router working already then you just need to add a computer to the network.
Click Here for step by step solution
Oct 27, 2009 | NetGear RangeMax WPN824 Router
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
Ipod touch not connecting to router
wireless router wpn = password check under your router for a passcode or somewhere on it or call your nearest internet place
Jan 08, 2009 | Apple iPod touch
Need my passphrase for my netgear wpn824 wireless router
Are you trying to setup your router? If so..
Here is a list of Netgear WPN 824 Models. :) USERNAME PASSWORD
Netgear WPN824 v2 (Netgear Firmware) admin password Netgear WPN824 v3 (Netgear Firmware) admin password
Netgear WPNT834 (NetGear Firmware) admin password
Jan 07, 2009 | Computers & Internet
Connect netgear wpn824 to DSL router using usb connection between DSL router and wireless router
call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
Dec 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Trying to hookup a wireless router to HP 1100
DSL uses PPOE, which may be different than what you had previously. Cable, for example, uses TCP/IP.
Re-set the router to defaults, and follow the instructions for PPOE, which should be in your manual or setup disk. Your ISP may have this info on their site, or you can get it at the Netgear site:
www.netgear.com
Oct 17, 2007 | 2wire HomePortal 1100 Router...
NetGear RangeMax WPN824 Router Logo
222 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
