Question about Leedom Vandal Ski / Snowboard Helmet Small Black 50-52
Broken popper on chin strap
The inside of the chin strap popper has broken off. The bit that the earpiece attaches to has come away from the chin strap rivet. Can you get a new rivet?
Re-attaching the pull ******** the drivers door
Normally there are also other screws hidden behind chrome trims that you prise off with a plastic screwdriver. There are always plastic poppers all round the edges of the panel, use 2 screwdrivers slid in (one on each side of each popper) to lever the panel away from the door so that the popper comes out of the door.
Dec 20, 2013 | 1974 Cadillac Eldorado
My underwood 3 cord (makes the carraige move ) is broken,, i dont know how to fix it,,like where it should attach pls help!
If the strap or cord actually broke, you have to know what you are doing. The strap attaches to the mainspring which needs the proper tension by how many winds you give it. This can be a bit tricky and even risky if you don't know what you are doing. The strap connects to a pin or ear of sorts on the right underside of the carriage. Hope this helps.
Oct 22, 2013 | Office Equipment & Supplies
Are chin straps that help you stop snoring really expensive to buy? I am thinking of trying one but dont have a lot of spare cash.
I bought a chin strap that holds your mouth together to try and stop you from snoring, and it cost me around $7. I think I got it at Amazon but after that I saw it in my local pharmacy as well for around the same price.
But just be warned...I found mine really uncomfortable and my girlfriend said I looked like a monster in it, so I had to give it up after a week.
Feb 13, 2013 | Health & Beauty
I heard there is an anti snoring chin strap. Has anyone use one? And do they work?
I don't think so that any other device will work effectively for snoring is my personal experience. As I have already used and tried many options other than surgery. Even I took consultation through many doctors about my snoring problems, but no result. Finally I came to know about Asonor effective Anti Snoring solution
How do i move the straps to a higher/ lower **** ??
Hi
Undo the popper on the shoulder harness pads and slide pad down length of harness. You will reveal a metal D ring which is where the harness is attached to the anchor point. Unhook this ring. Remove the top of the seat fabric from the sub seat (seat frame) and you will find further sets of anchor points behind the fabric. Post required anchor point through the hole it lines up with and re-attach harness, then put harness pad back into position and do up popper.
Mar 24, 2012 | Quinny Buzz 3 - Rocking Black Stroller
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Scott Ski helmet chin strap velcro wrap is fraying where can I get a replacement for it, it is the soft chin pad through which the chin strap goes through.
macaasms-
You're best bet is to contact Scott directly. It may still be under warranty - even if it isn't, you may be able to get a replacement or repair at no charge...if they stand behind their product that is...
Scott USA
PO Box 2030
Sun Valley, ID 83353
1-800-292-5874
Hope this helps.
DIYpro
Apr 30, 2011 | Giro G9 Helmet for SkiSnowboard 2010
Not sure if the strap goes on the chin or under it or how to keep it tight
if it goes on the chin it will have a pad that looks like a bowl/cup. it will be molded like a chin profile. if it is just padding then it will just over the clip.
Sep 20, 2009 | Triple Eight Sports Triple Eight Old...
Leedom Vandal Ski / Snowboard Helmet Small Black 50-52 Logo
104 people viewed this question
Top Leedom Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you a Leedom Winter Sport Expert? Answer questions, earn points and help others
