Question about Canon PIXMA iP1600 Printer
My printer is installed into my computer im trying to print out a report but its not letting me. it tells me to turn the printer off then back on and i do so well the bottom light is still flashing
Tengo el CD de instalacion pero no quiere coger la intalacion y quisiera saber si hay otra manera de instalacion
Posted on Jan 17, 2009
How do I remove the ink cartridge
go to start menu, right-click computer, click manage, on the left double click device manager, when the menu is populated look for other devices, you should see your printer. double-click it. a menu will pop up, click the tab labelled driver, then click update driver, click the option that lets windows search for solutions/drivers online. this will find and install the drivers automatically the way windows knows best, this should fix the printer not detected issue and the printer should be ready for use. that is given that you have the latest kodak software installed on your computer. for some reason there is a compatability issue with windows 7. its the kodak software not windows 7. im looking for a way to report the issue to kodak now, hopefully they can resolve this issue to eliminate all this trouble. took me all night to troubleshoot my printer only to find that kodak hadnt corrected the issue on their end. I LOVE WINDOWS 7 :) hope i helped
Jan 21, 2013 | Kodak ESP Office Equipment & Supplies
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
We have installed some new print cartridges into the C5280 and we cannot get the printer to wiork. The window on the printer says, 'printer cartridges' refer to printer documentation. Anyone know what to...
Try to unplug the printer from the outlet and the computer, wait for 5-10 min. Then plug only the ac cord back to the wall, turn printer on and see what happens. If it seems ok, then plug back into your computer. Also there is usually a process in the printer program that lets tell the printer it has new carts installed.
Sep 22, 2009 | HP Photosmart C5280 Printer
MoneyCounts - Can print reports but not checks
Make sure when you get reay to print in your Moneycounts program that the right printer is listed when you tell it to print, if not use the down arrow beside the printer listed and list the right one. It is probably still set up on the old printer. Hope this helps.
Ralph woodworking57@hotmail.com
Sep 15, 2009 | Computers & Internet
HP PSC 1210 stopped working on a Dell desktop running Vista
Uninstall the drivers again, restart the computer, turn off antivirus, install drivers again, plug cable to another usb port when prompt, if firewall shows pop up window always choose allow or yes. Also make sure that printer is not working "off line", go to control panel, printers and faxes, right click on the printer that you want to use, check if it says "use printer off line", if it does, click on it and it will change to on line.
Sep 01, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have a Vista system, Home basic 64 bits. I want to print the report sheet from quicken 2008 for my income tax for 2008. I can not get it to print at all. I went through the "prepare a printer to...
Just to clarify can you print with other application that you have like Microsoft excel or microsoft word or you canot print at all? and by the way we're not connected to HP at all that;s why you need to pay the support from us..
Feb 25, 2009 | Computers & Internet
Communication error
Click on start-control panel-printers and faxes. Do you have more than one copy of the printer installed? If so, my advice is to uninstall them all and then do a new installation. But FIRST, make sure there are no jobs left in the print queue. Double-click each printer icon in turn and delete/cancel any print jobs listed. Then delete each "copy" of the printer and finally uninstall the printer using the Control Panel-Add/remove Programs-Epson Printer Software. After you have done all this, turn OFF the printer, reboot the computer and then re-install the printer. Make sure you keep the printer turned off until the installation program asks you to turn it on.
If none of this helps or is appropriate, or you want further information, please report back.
Feb 06, 2009 | Epson Stylus C46 InkJet Printer
No printing on epson c62 inkjet
Hi songerjohn
Turn off the printer. Click on start-control panel-printers and faxes. Double-click the printer icon and delete/cancel all print jobs listed. Then reboot the computer and turn on the printer. It should now print normally.
If it doesn't you will need to uninstall the printer using the Control Panel-Add/remove Programs-Epson Printer Software. After you have done all this, turn OFF the printer, reboot the computer and then re-install the printer. Make sure you keep the printer turned off until the installation program asks you to turn it on.
If none of this helps, or you want further information, please report back. If this solution has been helpful, please rate it.
Nov 20, 2008 | Epson Stylus C62 InkJet Printer
Printer won't print
Well could be multiple issues depending upon whether its installed on the network or through the USB.One thing you can try is unistalling the printer drivers from the computer in the control panel>printers and faxes and then reinstall the drivers.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Jul 24, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Error when trying to print
Can you please tell me the brand and model of your printer?
What errors do you see when trying to print?
May 06, 2008 | Office Equipment & Supplies
Canon PIXMA iP1600 Printer Logo
old marine
old marine
