Question about Acer TravelMate 6460 (LX.TED0Z.071) PC Notebook
Wont turn on
Last night i was using my acer when it just shut off...Now when i turn it on it comes on for a split second than the battery light blinks 3 times.I have the plug hooked up to it so itll charge but the battery charge light wont come on.Aside from the 3 blinks it gives after turning the laptop on
  • ma10070w Feb 03, 2009
    I have the same problem, I think. Removing the battery the laptop works fine, but of course is not a solution.
    Good luck.
  • 335 Answers
Pull the battery and try to power on. if no good test the power adapter with a meter - should give 18-19 volts. if it boots with battery off, power up and put battery back on to charge.
hope this helps
Posted on Aug 09, 2009
My Acer 6800 on button light comes on, wont shut off! Wont boot up all the sudden!
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 02, 2012 | Acer Veriton 6800 PC Desktop
I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
Nov 05, 2009 | Acer Aspire 7720 Notebook PC
Have an acer extensa 4630z wont start up
Bring your Laptop to the nearest Computer Center or any Local Technician to see your laptop. Laptop like this are problem with short circuit or manage power voltage connection.
Also it's having some trouble with motherboard pizza's inside.
Sep 23, 2009 | Acer Extensa 4620 Notebook
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Laptop wont turn on at all!
try sensing if your cpu fan is working, it is under the power switch side, you can see small exhaust slots, put your hand beside it and feel if some air is coming out when you turn on your pc.
When you turn you pc on and only orange light blinks, it means that no power was getting into it, it blinks because no electrical power is coming from your power adapter and the battery is drained. Check your power adapter cable, this is the very cause why your pc is shutting down. usually the wire from the adapter to the pc is faulty.
Nov 01, 2008 | Acer Aspire 3000 Notebook
Wont power up!
May be the battery is dead (i.e. uncharged). Connect to an electric network and try once.
Oct 11, 2007 | DFI NFII ULTRA-AL Motherboard
Acer TravelMate 6460 (LX.TED0Z.071) PC Notebook Logo
247 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
