Question about Kohler 12 kW Emergency Power System - 12RES-L
UU lowvoltage error code residential generator
Engine cranks, turns over briefly then shuts off and UU code appears.
Checked oil: OK
Suggestions?
  • t_jeepster May 03, 2009
    The red light on my fuse box started to blink constantly. So when I went to check the generator box, UU appears on the display. What does this mean and how can I fix it?
    Problem Solver:
  • 5 Answers
Could be the battery voltage. If your battery is not charging properly, the controller on the unit can do some funky things! Exactly how long does it run for? Is this in auto or manual mode?
Posted on Sep 04, 2009
Gas in crankcase
Fuel from the fuel tank flows to the carburetor and then on into the engine cylinders. From there it seeps into the crank case.
It's a matter of gravity. The gas will seep until it reaches the lowest point in the engine.
There are two methods of correcting this dangerous problem.
1) When you are done using the engine you can turn it upside down, over a large container that is of sufficient size to contain all the gas and oil that will run out of the engine.
or
2) Turn the fuel valve to it's OFF position when you are done running the engine. This stops the fuel from seeping into the crank case from the carburetor.
(And a heads up from one who has personal, first hand experience. Be sure to OPEN the fuel shut off valve when you think you would like to start the engine.)
If you should have this happen again DO NOT try to start the engine!
(That's one of the reasons The Da always said, "Did you check the oil before you started that engine?")
Dump out all of the oil that has been contaminated with fuel and replace it with fresh oil.
Dec 24, 2013 | Briggs & Stratton Power Products 5,550...
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
Code UU
Here is the code explained direct from Kohler's manual. I'd disconnect the generator load first.
UU Undervoltage Shutdown occurs if the voltage falls below 80% of the nominal system voltage for more than seconds. Check wiring and connections.
Reduce the load and restart the generator set. —
Check wiring and Check controller configuration, system voltage
and frequency (parameter UU).
Check AC voltage and adjust, if necessary. 5.7
Replace the SCR module and test voltage again. 4.9
Separately excite unit. 5.2
Check stator continuity
See web site for manual :http://www.kohlerpower.com/onlinecatalog/pdf/tp6196.pdf
Jul 11, 2010 | Kohler 12 kW Emergency Power System -...
What does over crank mean
Means that the engine has turned over for too long without starting. It times out to protect the starter and battery wiring.
May 22, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Nov 11, 2009 | Kohler 12 kW Emergency Power System -...
Generac NP 50G wont crank
Measure voltage drop across the far ends of the fuse wiring (should measure zero), as one of the wires or it's connection to either end of the fuse may be open. Check the battery negative grounding connection at the frame. If all ok, you may need to find a wiring diagram for the machine. Does this unit have a low-oil-level switch which will kill the engine if set?
Oct 28, 2009 | Electrical Supplies
UU undervoltage kohler 20kva
call koler but ui think is meant high heat as in the thermal circut is shuting you down or low oil
could be a couple of things best bet call kohler
Aug 06, 2009 | Kohler 12 kW Emergency Power System -...
Kohler 12 kW Emergency Power System - 12RES-L Logo
1,842 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
