Question about GPX MW-238B MP3 Player
I need help
I just got the mp3 and it did not come with a guide to work it. i need to know how do i play the FM radio and the voice recorder on it.
    Problem Solver:
  • 6 Answers
UM i have a 238 and they dont have a radio or voice recorder on it ... just plays mp3s .... should say right under screen mp3 digital player ... if it says radio on it somewher it must be differnt model  hope this helps
Posted on Jan 29, 2009
How do I record FM radio programs and transfer them to my computer?
unfortunately, the voice recorder works only as voice recorder, it cannot play FM and record it at the same time. though you can play fm radio from another device and record it using your SanDisk mp3 player.
To transfer your recordings from your mp3 player, connect your device to your PC.
Open "My computer" from your PC and you'll there "your Sansa Player"
Double-click on "your Sansa Player", then open the "Music" folder, then, open "Recordings" folder.
You'll find all your recordings on that folder.
May 14, 2010 | SanDisk Sansa Clip MP3 Player
My mp3 player is stuck in the voice recorder menu frozen
try to find a hole in your Mp3 player. it should a pin size hole. you must insert a pin to Reset the Mp3 player ... it would fix
Sep 02, 2009 | Insignia Sport MP3 Player
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
Go gear will not operate in recording mode
The Go Gear SA52XX series is only capable of recording FM in Europe - the US versions, even though they have the same manual, will not allow FM Recording. I haven't heard that won't do voice recordings, but it doesn't surprise me - update the firmware - the directions are on Philips website. If it still won't record voice recordings, get a different mp3 player, because this is not the one.
The Philips SA6045, SA5125, and a few others will do FM and voice recordings. Ironically, the newer Philips GoGear's will not.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Fm radio and recorder modes
On this model, the Power button and the Menu buton are the same key - press the Menu button to go to the main menu, and it will display FM and Voice options.
Here is a link to the user manual:
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa c200 MP3 Player
Lost instruction
ok lamar230990 to turn your mp3 player to msc mode disconnect it from the computer and turn it on. once it is on go to settings and scroll down to protocol and click on it with the play/pause button. this should turn it to msc mode then connect back in to the computer and go to this site to download the software
Oct 22, 2008 | RCA M4204 MP3 Player
I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
Do this procedure for "voice" mode to delete voice recordings:
Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
1. In stop interface (FM without stop interface)
2. Short press "MODE" to enter stop submenu
3. Click "NEXT" or "PREV" to choose "single" or "all" files
4. Short press "MODE" to enter the Delete interface
5. Click "NEXT" to change "no" into "yes"
6. Short press MODE to confirm the delete prompt
"Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
-Tha Mp3 Doctor
Jan 08, 2008 | Centon Electronics MP4-001 MP3 Player
Software is deleted
my mp3 players software is deleted when i was downloading when i put the player to my computer it doesnot show the folder(drive)which previously was present.after this happended my player shows written in it disc error whenever i try to play the mp3 player.but the fm radio is working .so if you coukd assist in solving this problem
I need to know the website address for my logik mp3 player and voice recorder so i can download and reinstall its software. i can't find it
Dec 10, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
GPX MW-238B  MP3 Player Logo
69 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
