Question about Mitac Mio 168 Pocket PC
Problem with charging lead(s)
My power lead, both 12v car adapter and 240v mains appear to have a loose connection with the PDA. Resulting in poor charging capability. On many occasions i get a flickering orange charge light and have now realised this does not constitute full charging. The unit is 2 years old and has never let me down (odd soft reset reqd.) Anyone had a similar problem or know where i can get it resolved Thanks PS At present to get a full charge on 240v i have to hang the unit upside down over a PC monitor ? Obviously something is damaged somewhere !!!! Mark
You will have to send it to a service support centre to get the connector repaired.You can buy it for approx £17 or send it to the centre for repair.it is a common fault with this machine.the connector is soldered on to the printed circuit so unless you are confident in repairing it i would pay the extra and give it to someone who knows what they are doing
Posted on Aug 20, 2007
SOURCE:
What switch position should I have for 12v & 240v in a millard 2002 van
The 12v & 240v switch is to change voltage supplied to the camper. You use the 12v if you are running things from the battery; you use the 240 when you're connected to what the US calls "shore power" or "land power"
Mar 24, 2015 | Cars & Trucks
No 12volt supply unless connected to 240v mains
the power invertor could be the peoblem, or the fuse to the `12 volt supply sockets
Nov 09, 2014 | RVs
Need to buy a charger for my Hyundai S900-charger 100-240V 50/60Hz 9v-2.5A, saw on Amazon you had thisCostMad 7 / 6 Way 1.5A 1500mA max. AC to DC Universal Universally Multi Voltage 3V / 4.5V / 6V / 7.5V /...
You can buy car accessories here,they are one of the best electronics wholesales in China. http://www.ankaka.com/Wholesale-car-accessories_c10005
Feb 18, 2013 | Televison & Video
Can a 12 v supply be used for ferg.f1604levd straight from a 12v battery
a 12V battery from car??
in cars battery are actually between 14V(fully charged) and 11V(empty)
else i don't know but the best way to be sure is using a regulator (this for example)
Nov 21, 2012 | Computers & Internet
Need car adaptor for bmr100 12v to12v
As they don't make one you have 2 options.
1) Buy another Mains Adapter and Cigarette Lighter Plug, Cut the Cable & Connect to the BMR100 and connect it to the Cigarette Lighter Plug.
2) Buy a small (100W) 12V to 240V Inverter and plug your existing Mains Adapter into this. You'll get one from eBay for about £10.00 to £15.00.
May 05, 2011 | Makita BMR100 Radio
Compatbility of product in Australia?
if you connect the boombox direct to the your mains of 240v, the appliances will blow up , to avoid that you need a step down transformer to connect the boombox before it goes into the mains source. you do not need any adapter, only if you want to use battery that is when you to swicth to 12v
May 25, 2010 | Lasonic TRC-931 Cassette Boombox
Car won't even turn over
Sounds like either:-
1) a loose or poor connection on the main +12V supply feed, (check fusible link or in line 'Maxi' fuse connections to main fuse panel.
or
2) a loose or poor ground connection between the battery and chassis.
Check all ground bus's for corrosion or looseness.
Sep 22, 2009 | 1986 Ford Crown Victoria
PDA would not turn on...
try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Jul 24, 2007 | Dell Axim X51v Pocket PC
WRONG VOLTAGE
no as long the player is not damage you can still match the voltage because the 12v is not going to turn on or work properly on the h320 because the voltage is not right. Unless if you have a closer voltage like 4.5v or 5.2 v it will be good it will work.
Example:When i bought my pda it did not come with adapter so they gave me an alternative adapter is supposed to 5v but they gave me 6v to try out first it work then second try i turn my pda using the ac it have problem with voltage because is too high than 5v. The next thing i did is buy another adapter good thing i found closer to 5v which is 5.2v which is it work.....now by pda work..properly and i can charge it properly too.. well it takes sometime to look around the shop until it can be found the right adapter....
Well i used the USB to AC adapter 5.2v...it work great... for mp3 player like h320,pda........
Mar 04, 2007 | iRiver H320 MP3 Player
Mitac Mio 168 Pocket PC Logo
76 people viewed this question
Top Mitac Computers & Internet Experts
gerry bissi
Alun Cox
asber
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
