Question about Whirlpool Refrigerators
Tightening a refrigerator door handle
I have a Whirlpool side by side, model #ED22PW and the door handle has loosened up and I don't know what I have to do to get at the screws to tighten it.
5 Suggested Answers
SOURCE: refridgerator door handle
some there is a plastic sleve or cap you push up to get to it some you open the door and pull back on the gasket to get to hard to know without mod num
Posted on Dec 30, 2007
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
SOURCE: Ge profile refrigerator door handle is loose
On the GE Profile, the handle is mounted to two small screws. To detach the plastic housing, you must press on the two connection points (the base and top of the handles) and slide the handle up or down (takes some effort). The handle will come off and you will have very easy access to these 10mm screws.
Posted on Apr 09, 2008
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
  • 4 Answers
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
How do i fix a wobbly door handle?
Wobbly door handles are the result of loosened screws / bolts. ON side x sides, there is usually trim above and below the door handles that can be slid off away from the handles to expose these screws.
Dec 10, 2010 | Whirlpool GC5SHEXNS Side by Side...
Need to reattach door hndle
yes i need to fix the doors handle their are loose and i want to tight it up, but i don´t know how to do it
Feb 21, 2010 | Whirlpool GS2SHAXM Side by Side...
Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Feb 24, 2009 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool ED22PW water not reaching ice maker or front dispenser
It doesn't matter if a whirlpool or any other brand is new or not, if you don't use an inlet water filter the water will taste like **** and sediment will deposit and cause catastrophic ice maker and water dispenser failure.
Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
I need new refrigerator door handles?
Go any appliance parts website and look up your model, you should be able to order them online
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
112 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
