Question about Mitsubishi WT-46807 46" Rear Projection Television
Convergance problem well..turn on the set, its fine for a while then the color with red green blue is off convergance. i giggle the tv around and it fixes itself? any ideas?
    Sergeant:
  • 233 Answers
Welcome!
You have bad solder joints in your tv.
If you have any electrical or soldering experience, you should be able to fix this yourself.
Semove the back cover of the tv. On one of the boards, you will see a very large heatsink, with two IC's mounted to it that have a number like STK392-250 or STK392-120 - something like that.
you will also notice around those IC's there are some "larger than usual" resistors... If you take your soldering iron and re-solder all of the resistors, and all the legs of the IC's , I can give you about a 90% chance your problem will stop.
Posted on Jan 17, 2009
Can not get the focus grid to line up correct green adjusts fine but blue upper left corner will not adjust and the red grid is way off and will not fix
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 08, 2011 | Samsung HC-P4752W 47" Rear Projection...
The Blue color is double imaged and when i do the magic focus, red and green do fine but blue the "bars" at the top are smudged and there are no bottom bars showing.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 27, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
No blue auto convergence when performed by menu buttons
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2008 | RCA HD52W59 HDTV Projection Television
SONY KP-43T75 HAS ISSUES
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Sep 21, 2007 | Sony KP-65XBR10W 65" Rear Projection...
How to adjust red blue green
if ur in service mode already..turn down all drive.green first turn it up until the desired intensity is achieve.then blue all the way until it almost blend the green.u must not see one color either too much green or blue.turn up red now,let it blend until u see a perfect black and white.note:make sure that the color level is set to minimum and tint to center. ihope i help u..
Mar 20, 2007 | Toshiba 43H71 43" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
